Old 03-06-2015, 10:35 PM   #1
bcontractor
bcontractor's Avatar
Red face aftermarket inner fenders
Just curious if anyone has had any luck with aftermarket inner fenders ? Do they fight good ??
bcontractor is offline   Reply With Quote
Old 03-06-2015, 11:15 PM   #2
dodgiesdad
dodgiesdad's Avatar
Re: aftermarket inner fenders
I cant speak of just the inner fenders. I recently built my entire front end using aftermarket panels, I had a lot of alignment issues with the whole clip. I had to trim some off of the backs of each inner fender and drill out some of the spot welds and re-weld them on the front for better alignment. I also trimmed and adjusted all of the other panels. The used hood I got fits well at least.
dodgiesdad is offline   Reply With Quote
Old 03-07-2015, 03:01 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I have a set that worked ok, main problem was that the steering column cover area either had the nuts in the wrong place, or just not there,,, I can't remember which
seems like most problems I have seen mentioned on the board is when people are trying to use an entire aftermarket front clip.. that's where all the fitment issues start... I just used the aftermarket inners, all my other sheet metal is original
Old 03-07-2015, 10:39 AM   #4
Joe Pass
Joe Pass's Avatar
You can still find originals around...I just scored a whole front clip rust free on craigslist. The seller didn't even know it was rust free....I would repair yours or find some originals before I considered the repos just from my experience.
Joe
Joe Pass is offline   Reply With Quote
