Old 03-07-2015, 09:26 PM   #1
Pullen
Lowering kit plus trick springs in the front?
i was wondering if its possible to lower my truck 6/4 with this lowering kit http://www.summitracing.com/parts/wst-70400/overview/ then later down the road put a pair of moroso trick spring under the front. my truck is a 71 gmc long box
Pullen is offline   Reply With Quote
Old 03-08-2015, 10:43 AM   #2
Rod Run
Rod Run's Avatar
Re: Lowering kit plus trick springs in the front?
Why you going with the Moroso springs later, do you plan on your truck being a track vehicle?
Those springs are not good for the street. They don't have enough stability in them for handling around corners, to make them a good driving spring. They are really designed for drag strip launches and easy weight transfer. They are also usually used without a sway bar.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-08-2015, 11:41 AM   #3
Mike C
Mike C's Avatar
I ran the trick springs in a 68 Camaro I had. And I HIGHLY recommend that you don't...
You should be able to make the truck weight transfer and hook with using either stock or lowering springs and maintain some civility to it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-08-2015, 04:41 PM   #4
bdiamond
The stock spring rate is in the 750ish range for a stock SB truck. The Moroso heavy spring is about 300ish IIRC. The moroso spring is about 20 inches free length maybe more. I bet it would be a nightmare installing them. I would think they would be nearly coil bound at ride height.
bdiamond is offline   Reply With Quote
