Old 03-07-2015, 09:28 PM   #1
bigdaddy51200
Viper 211HV Keyless Entry Install on 1990 Truck
I got my keyless entry system installed today and it works great. I bought the system from amazon for 35.00. I want to give all the credit to John H here for the great YouTube video.https://www.youtube.com/watch?v=02aOrzdSIDM
Here is how I wired this up.
Viper 211HV
Drivers side (Lock) White/Black wire
Passenger side (Lock) Green/Black
Driver side (unlock) Brown/Black
Passenger side (unlock) Blue/Black
Constant power Purple\Black
Ground Black (ground to steering column bolt)
Parking Lights White (to headlight switch)
Red (Power under steering column)
Brown (to horn under steering column)
My 1990 Truck
Drivers side (Lock) Light Blue (cut in half) (Pull driver side speaker to access)
Passenger side (Lock) Light Blue (cut in half) (Pull driver side speaker to access)
Driver side (unlock) Black/White (cut in half) (Pull driver side speaker to access)
Passenger side (unlock) Black/White (cut in half) (Pull driver side speaker to access)
Constant power Orange (splice into) (Pull driver side speaker to access)
Parking Lights Brown (splice) (headlight switch)
Black (splice) (horn under steering column)
Here is wiring diagram for my truck that I found here :http://www.the12volt.com/
Constant 12V+ Red Ignition Switch Harness
Starter Purple Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Brown (+) Light Switch
Head Lamp Yellow Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Light under Dash
Door Lock Light Blue Driver's Kick Panel or left Dash Speaker
Door Unlock Black/Red Reverse Polarity
Horn Wire Black (-) Steering Column
bigdaddy51200 is offline   Reply With Quote
