Old 03-07-2015, 11:33 PM   #1
Vals59
You are subscribed to this thread Patch panel repair pictures and advice
I just got started replacing my cab corners. My rocker was pretty rotted and bent making it hard to decipher exactly where to line it up. A picture of where the rocker meets the cab corner would help me as the inside corner of the rocker could be my guide. Also someone had a picture in their build thread of plate they made for the floor that took the place of the inner cab corners. After working on it today and seeing all the stuff that was trapped inside I am all for leaving them out if its o.k to do so. I have the cab on a fixture I made that the cab bolts to just like its on the frame. I have rockers and step plates and some work to do around the hinge pocket. My plan was to fit everything starting at the cab corner and work forward. I plan to use self tapping screws to hold it all together before I do any welding. Any advice is welcomed. I have looked over several build threads preparing for this. Just trying not to over think it or over look something . Thanks Mike
Vals59 is offline   Reply With Quote
Old 03-07-2015, 11:42 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: You are subscribed to this thread Patch panel repair pictures and advice
Butt weld everything, no overlapping joints because they are just traps for moisture and future rust - so no self tapping screws.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-08-2015, 12:54 AM   #3
mr48chev
mr48chev's Avatar
Follow what Dan said for sheet metal panels you are going to finish and paint on the outside of the truck.
An overlapped seam not only is a magnet for moisture and then rust it means that you have far more finish work to do to get it smooth and it may still show through the finish paint.
My ongoing truck projects:
Old 03-08-2015, 08:38 AM   #4
Vals59
Point taken thank you. The cab corner is fitted to be butt welded,still mat need a little tweaking but it`s real close. Leaves me with the question of the inner cab corners, and rocker to cab corner alignment.
Mike
Old 03-08-2015, 11:01 AM   #5
Kim57
Kim57's Avatar
I eliminated my inner cab corners and made these for the inside of the cab.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-08-2015, 12:46 PM   #6
OrrieG
OrrieG's Avatar
Are your front door hinges good? You should mount the door to set the front, top and upper back gaps, that will show you where the sill and corner jamb needs to go.
OrrieG is offline   Reply With Quote
Old 03-08-2015, 02:26 PM   #7
Vals59
Kim pretty sure it was your build thread I had seen those in Thanks.
Orrie working on setting the door on now thanks
Old 03-08-2015, 02:58 PM   #8
roger55
roger55's Avatar
I detailed how I did all those things in my build thread. I posted lots of large photos too. Use the link in my signature.
roger55 is offline   Reply With Quote
Old 03-08-2015, 04:34 PM   #9
Vals59
Thank You Roger I will check it out.
