03-08-2015, 02:33 AM | #1 |
Engine/transmission recommendations on 70 c10 swb
I am building a 70 c10, it currently has a stock 454. I am looking to go with something different in small block from but plenty of power. I was looking at the 376 chevy crate engines but was looking for around 600-700hp. I am on a budget of course. Thanks. Please post pics if you have some engine swap pics
2005 Chevy Silverado 2500HD- DD 1970 Chevy C10 SWB 454 BBC- Work In Progress |
03-08-2015, 10:24 AM | #2 |
Re: Engine/transmission recommendations on 70 c10 swb
To get that kind of Hp, it takes big inches, high RPMs, or a power adder.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-08-2015, 10:30 AM | #3 |
Your not going to get there easily with a small block. You already have what you need right in the truck. Bore it out and buy a 496 stroker kit and go from there if you want to get to the 600-700 range. A LSX376 is nice but you can spend a lot less and have more than the 450hp its rated at with a 454/496.
1972 C10 Cheyenne 402/TH350 1985 GMC 1500 Sierra Classic 350/700R 1986 K20 427/NV4500 1986 K20 Sub 406/TH400 "Life's tough.....It's enough tougher if your stupid." John Wayne |
03-08-2015, 10:36 AM | #4 |
[QUOTE=1970chevc101994;7080836 but was looking for around 600-700hp. I am on a budget of course.[/QUOTE]
Obviously you are pretty new to engines? Do you know exactly how powerful and expensive 700 hp is? And on a budget? Put a 350hp nitrous system on your 454. At least you can hit the 650 mark once or twice... Honestly, the 376 motor would be great in your truck. Or a Blueprint engines 454 for about the same price. But the GM warranty is awesome if your truck fits in their list. Not trying to be rude, but somebody building/using 700hp wouldn't be asking this question and would understand the expense involved and the limits to the ability to harness a real 700hp on the street.
03-08-2015, 11:12 AM | #5 |
700 hp out of a 376 on a budget is funny. I actually laughed out loud!
I built my 696 hp 355 almost 12 years ago for 21 thousand. I wouldn't want to think about what it would cost in today's dollars. I have seen articles about junkyard 5.3 ls motors with turbos that produce between 450 to 600 hp for reasonable prices. Reasonable in that case would still be at least 10k.
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
03-08-2015, 11:35 AM | #6 |
My budget it 15k. I said budget because I know a lot of good reliable engines with that horspower with run 25-35k. Don't assume that my budget is 2k. Thanks for the information though
03-08-2015, 11:58 AM | #7 |
I forgot to mention that once you have 600+ horsepower, then you have to upgrade your torque converter or clutch, driveshaft, rear end, gear set, motor mounts, exhaust and more.
03-08-2015, 12:15 PM | #8 |
Transmission is already built. Has a 9" rear end in it from moser and waiting on custom made driveshaft
03-08-2015, 12:22 PM | #9 |
http://www.shafiroff.com/chevy_crate...34_bigdawg.php here you go...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
03-08-2015, 11:10 PM | #10 |
03-09-2015, 12:45 AM | #11 |
junk yard 5.3 with a turbo/turbos ls2/3 heads and a good boost controller. it will get you there fairly easy and should be in your budget and easy to drive. Just bump up the boost on the controller when you want it and down when you dont.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-09-2015, 01:12 AM | #12 | |
I'm building a turbo 5.3/4L80E/9" for my '70 now. Trust me, the engine is the cheap part of the build. If you get a 4.8/5.3 with the Gen IV rods you can reliably produce 700+rwhp with the stock shortblock and a good tune. Engine management is also a considerable cost, the stock PCM is capable but at some point aftermarket becomes advantageous. I went with the Holley Dominator. Check out Sloppy Mechanics for some low buck inspiration and ideas for the turbo LS world. Good luck with the project. And buy brakes. And steering upgrades. |
03-09-2015, 08:51 AM | #13 |
Cla511, they actually aren't to far from me so I am going to go check them out. Thank you
03-09-2015, 09:13 AM | #14 |
We want pics of whatever you choose.
03-09-2015, 10:10 AM | #15 |
You should easily be able to build a 496 stroker that'll make that power for your budget.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
03-09-2015, 10:37 AM | #16 |
I think another consideration is what you want to do with the truck? Road racer? Probably would go with a lighter ls series motor for weight savings and high rpm. Drag racer? big block power... etc etc. End goal is important.
03-09-2015, 10:53 PM | #17 |
My end goal is just a fast weekend truck. It will have no bed floor, gutted cab, and roll cage. Nothing fancy, just every thing built tough and strong. So I am going for, light, strong, and fast. Think I will go with ridetech 4 link coil over kit for the suspension to put the power to the ground. Might just say save my pennies and put the project on the back burner for a year and buy a 572 from this company in michigan.
http://m.ebay.com/itm/231493277516?nav=SEARCH
03-10-2015, 03:18 PM | #18 | |
Here is a little info about heads http://lsx4u.com/lsxinfo/heads.html to the op if you are unfamiliar with ls motors I would consult someone who is as they can easily be purchased and installed in your price range With the power you want As long as the correct cam/heads/block are matched up. Let us know what you choose!
03-11-2015, 01:47 PM | #19 | |
The biggest problem with our trucks in not how much power you can put in them and get them to make but how much can you get to the ground. You can put in 700 hp and make a lot of little circles but I would rather go straight. For 2-4 k if your block is still in good shape you can have a very nice 454 with a lot of power. That leaves at least 10k for beer
03-11-2015, 02:40 PM | #20 |
Just Google HotRod Magazine's "Big Bang Theory" or search for Sloppy Mechanics Turbo Build. 600-700hp is WAY EASY for 3500 bucks!!!! The day of bigblock streetcars to be fast is over!! Guys that are stuck in the 70"s think only a bigblock can be fast- time to step into the EFI world. And that bigblock will never get 17-20 mpg, like my turbo LS does!!
03-11-2015, 06:47 PM | #21 | |
03-11-2015, 06:51 PM | #22 | |
03-11-2015, 07:09 PM | #23 | |
03-11-2015, 07:10 PM | #24 |
Considering you already have a 454, I'd say build that.
Then make sure you get out there and drive. I've found the key to enjoying any project is not only the build and "dream" stage, but actually putting some miles on afterwards. Hit the track, make some passes, do Power Tour if you can, etc. |
03-11-2015, 09:47 PM | #25 |
Fitz- it all depends on where you get your parts and how much time and effort you put into making everything work together. I know what things cost, and I know where I can save money and where I can't. And also don't believe, I ever mentioned going with the small block after I said I was going to put the project on the back burner and save up for a 572 which I had a link to.
