Old 03-08-2015, 11:07 AM   #1
artie's65c10
Question Getting started on 65 c10
I have a 65 c10 fleetside longbed which needs a lot of body work, i found a 64 c20 that is for sale and was thinking of buying it just for the body. Do you guys know if this will work? To me both front fenders and the bed look exactly the same. Thanks for the help in advance.
artie's65c10 is offline   Reply With Quote
Old 03-08-2015, 12:51 PM   #2
Jeff La
Re: Getting started on 65 c10
All the same
Jeff La is offline   Reply With Quote
Old 03-08-2015, 07:27 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
All the same style but mind you, watch out for slight changes in bolt patterns that will cause bolts not to line up with holes. Used 64 chevy fenders on my 66 and most of the holes lined up except for almost all the grill panel holes. So if you change fenders I'd use the same grill panel as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-10-2015, 09:35 AM   #4
artie's65c10
Thanks guys
c10 2wd fleetside longbed, c20
