Lowering Help
I want to drop my 1985 Silverado C10 so my 4'10" wife can get into the truck easier without doing any cutting to the frame. maybe just some spindles 2 1/2 front and whatever in the back.
Re: Lowering Help
I have a lot of clearance as you can see.
Re: Lowering Help
Can I run the Leaf springs under the axil and get shorter shocks? Or will that effect handling?
Re: Lowering Help
You should probably use the search button but shackles/hangers will give you 4 inches and level you out with the drop spindles in the front.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Re: Lowering Help
You can flip the rear springs an get shock extenders so you can still run stock length shocks. You'll need to cut one coil off your stock springs up front or get 2" drop springs to go with the spindles or the back will be lower than the front.
Flipping the axle won't negatively affect the handling
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
