PCV Question
I'm cleaning up my engine and noticed the PO never connected the PCV to the vacuum source. After using the search, I found the brake booster connects to the carb vac port and the PCV connects to the manifold vac port. Ok, that is all well and good, however, mine has the booster connected to the carb, the PVC is disconnected, and the mani vac port is connected to what appears to be a trans line. So where do I connect the PCV at? Thanks in advance.
Paul
72 C10 lwb fleetside -stock 350/350 combo |
Re: PCV Question
Have any pics? Worth a thousand words...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: PCV Question
My PCV connects to the bottom of the carb base.
My Power booster and trans vacuum line connect to a vacuum port between the carb and the dist. in the intake.
Terry Soon to be retired and moving to Bristol, TN. |
Re: PCV Question
The way tcrist has his is the normal way.
If you need a new vacuum tree, look here. https://www.paragoncorvette.com/c-22...aspx?pagenum=1 |
Re: PCV Question
Yup, nailed it. I looked at my tree fitting and it is the Wrong one. It has two 1/4 nipples on it. Thanks for the help guys.
