Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-08-2015, 02:32 PM   #1
fokker
Back up camera
Can anyone tell me where to wire up backup camera wire for a flip up head unit. The white and green wire on head unit is suppose to run to a reverse indicator light. It's a 71' swb automatic.
fokker is offline   Reply With Quote
Old 03-08-2015, 07:42 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Back up camera
Do the backup lights work? If so you hook them in to your light switch for the backups. Should be on the NSS down around the bottom of the steering column.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-08-2015, 08:03 PM   #3
fokker
Re: Back up camera
The reverse lights are not working. ..been trying to find a bad fusible link
Old 06-10-2015, 05:13 PM   #4
1malo68
1malo68's Avatar
Re: Back up camera
I just hooked mine up to a 3 position toggle switch ON-OFF-ON. I ran power to the middle spade and push down on the toggle for my rear camera and up for the front camera
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
