Old 03-08-2015, 05:45 PM   #1
davecarney2
davecarney2's Avatar
white walls or black walls
I really like white walls and it was always the plan but for a truck I am planning on driving almost daily they are so expensive. What do ya think? White walls or black walls. It lays out flat on the ground. I need to pull the trigger on a set of tires one way or the other. ●●●photoshop anyone●●●?
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
http://67-72chevytrucks.com/vboard/s...d.php?t=592878
davecarney2 is offline   Reply With Quote
Old 03-08-2015, 07:00 PM   #2
crossfire84
crossfire84's Avatar
Re: white walls or black walls
i like ww.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 03-08-2015, 08:18 PM   #3
Kim57
Kim57's Avatar
I like both depending on the truck.
On yours I would probably go with the black.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-08-2015, 08:24 PM   #4
Sim6
Sim6's Avatar
White walls hands down!
Sim6 is offline   Reply With Quote
Old 03-08-2015, 08:33 PM   #5
dubds10
Stalker Nate
Black until the rust is fixed then WW's lol Black looks better on that year tho and WW suite '47-54 better I think. But there are some killer 55-59s on WW but need to be done right.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 03-08-2015, 08:44 PM   #6
Henry50
Henry50's Avatar
Henry50 is offline   Reply With Quote
Old 03-08-2015, 09:17 PM   #7
davecarney2
Thanks for the input and photoshop
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 03-08-2015, 10:13 PM   #8
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I vote for the Blackwalls!
ChuckDriver is offline   Reply With Quote
Old 03-08-2015, 10:32 PM   #9
nvrdone
Build it the way you want. How about ww one side, bw the other side. That way you get the best of both worlds
nvrdone is offline   Reply With Quote
Old 03-08-2015, 11:20 PM   #10
MyDream55
Whitewalls
MyDream55 is offline   Reply With Quote
Old 03-08-2015, 11:20 PM   #11
Northern lights
I would go with headlights and a hood before shopping for tires. However, since you asked for tire recommendations, if you plan on finishing the truck (body work and paint) then I would go with WW. If you are not planning to finish the truck, BW will be fine and save you some coin.
Northern lights is offline   Reply With Quote
Old 03-09-2015, 06:57 AM   #12
davecarney2
Thanks for the suggestion. that was an old picture but only somewhat recent side shot. I plan on leaving the outside (at least for a while) so I am leaning twords blackwall I think.
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 03-09-2015, 07:40 AM   #13
davecarney2
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 03-09-2015, 08:02 AM   #14
lv2tri2
I would not put white walls on anything, particularly a driver. Just an opinion.
lv2tri2 is online now   Reply With Quote
Old 03-09-2015, 08:16 AM   #15
68shortwide
68shortwide's Avatar
That's a tough decision....WW would make it look cooler and more of a classic custom look, but BW would give it more of a performance look and a bit more bad@ss. Jmho. Cool truck.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 03-09-2015, 09:04 AM   #16
GMCNUT
GMCNUT's Avatar
I don't care what tires you put on it, just that you remember to not do any modifications that prevent someone from changing it back to original and that you remember to contact me first when you get ready to sell it LOL
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 03-09-2015, 10:27 AM   #17
mr48chev
mr48chev's Avatar
What ever blends in best with the package you are trying to present. Blackwalls on painted steelies with caps and rings can look every bit as good as white walls if you are going for the old time look.
In the 50's or early 60's a lowered custom truck would have had to have whitewalls and those whitewalls would have reflected what the new hot lick whitewall was in that particular time frame. Where guys building a truck with white walls now seem to think they need the big wide gangsta white walls a guy building that truck in 1959 would have run what was current in 1959 and that was a narrower white wall. If he was building it in 1962 he would have run the narrow white walls as that was the latest hot lick thing. Pretty much as the guys today go to the tire store and come home with what the kid at the tire store tells them is the Hot lick of the week rim and tire combo.
You can always put on a set of daily driver blackwalls now with some small caps or what not an then after the truck is finished buy a set of whitewalls for when you want to have the whitewall look for shows and that would give you two looks and allow a set of spendy whitewalls to last a lot longer.
My ongoing truck projects:
Old 03-09-2015, 11:54 AM   #18
Dan in Pasadena
Dan in Pasadena's Avatar
Agree. White walls are too faddish for me, AND too expensive.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-09-2015, 11:57 AM   #19
davecarney2
mr4chev thanks for all the great info. I think blackwall it is.
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 03-10-2015, 01:11 AM   #20
zenchal26
zenchal26's Avatar
ww
build thread zenchal26 project 57
zenchal26 is offline   Reply With Quote
Old 03-10-2015, 09:53 AM   #21
iowaboynca
iowaboynca's Avatar
either option looks good. Something to think about if the truck is going to be a daily driver. I have white walls on my bike that i use as a daily driver and its a PAIN to keep them clean! Something to think about...either way your truck looks good!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 03-10-2015, 11:48 AM   #22
curmudgeon
Nothing beats the great look of whitewalls on period correct steel wheels with the hupcaps and trim rings. However, since you indicate the truck is a daily driver, the 2-3x cost of WW makes the blackwalls the tires of choice for practical reasons. In addition to wider size selection, you can narrow your pick for function as well, all season, longer wear etc.
curmudgeon is offline   Reply With Quote
