03-08-2015, 10:22 PM | #1 |
91 suburban interior into 77 c10
I have a 91 suburban parts truck. The running gear is being swapped into a 69 c20. will the tilt column,seat belts, bucket seats and console work in my 77c10 longbed. also, will the late model wiper motor switch over so that i have intermittant wipers
Thanks for any help Last edited by lowbucktrucks; 03-08-2015 at 10:51 PM. |
03-09-2015, 09:23 PM | #2 |
Re: 91 suburban interior into 77 c10
bump anybody at least know about wiper motor and/or column
03-09-2015, 11:06 PM | #3 |
From what I have read you have to use all the wiring to get the intermittent wipers, and swap the motor over too.
03-09-2015, 11:17 PM | #4 |
It wont be a straight swap...wiper switch being on the column and being on the dash in your 77, bucket seats will require the inner front brackets being transferred from the burb to your c10...or you could fabricate your own. Its been done before, just search the web...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
03-10-2015, 09:55 AM | #5 |
78K & 79C Jimmys
I'd watch the 77 steering box to 89 tilt,should need the lower (91)shaft.
But watch some use different size rag joints. I've heard the wiper motor wiring is different after 78, the seats ,prob just need new holes my 89 seats fit into my 78,using 89 dash pad and door panels,glass etc too. (I have an 88 tilt for it too)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-10-2015, 06:29 PM | #6 |
Thanks for help everybody
motornut is your 78 a truck or suburban?? |
03-10-2015, 06:34 PM | #7 | |
78K & 79C Jimmys
The 78 has glass fuses,told later 78s were made with blade fuses. I've had a 78,87,88,89 Burbs before
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 03-10-2015 at 06:40 PM. |
