Help with some engine codes?
So I am looking for a year correct 327 to go in my pickup. I found an engine and these are the numbers
TII07HC on the deck 3903352 on the back of the block Thanks folks.. ![]()
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) ![]() |
#2 | |
Re: Help with some engine codes?
http://webpages.charter.net/darrell1...g_numbers.html OK I'm not so good at serial numbers but I'm getting: T for Tonawanda plant, 11 for November, 07 for day of the month, and HC for 327 V8. http://www.nastyz28.com/chevy-engine-code-stampings.php http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php |
3903352 comes back as 1967,327.
HC in 1967 comes back as a 327, 275hp, 4bbl, originally mated to a powerglide trans, in a Impala . If you want to triple check it, get the date code off the block. It's in the same place as the casting number only on the other side of the block. Mechanicalman, you nailed it nice work!
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-09-2015 at 08:49 AM. |
Thanks guys
now the guy wont reply and this is the motor i need
![]() Join Date: Nov 2001
I can relate to how you feel.
I have been looking for the correct motor for quite awhile.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Okay so now i got a differerent block. its a small journal 2 bolt with a casting code of 3782870 i went on nasty z28 adn it came up as a 62-65 327 with 375 hp! cool so now i am assuming that its a corvette motor but i cant decipher the codes on the deck it appears to be 5k110514 BUT the 1's are upside down? also the 0 might be a u i will try to post a picture here in a minute
This is that 327
Yes that's a 327. 3782870 comes back as a 327. It's a 65 and it has a partical vin, so that's a clue that it's 300 hp or more, but you need the engine ID number located to the right of 5K110514 to narrow it down even more. It starts with F, then 4 numbers, then 2 letters. It's the 2 letters at the end that we need to narrow down the application.
5K110514 5 = 1965 K = Kansas City 110514 = sequence number
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-11-2015 at 07:06 AM. |
I bet there is a person out there with a 65 Corvette with VIN number ending in 110514 that might be looking for that block. You never know.
#10 | |
Corvettes were only built in St Louis during that timeframe. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-12-2015 at 03:05 PM. |
Keith, How do you know it's a corvette motor?
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-11-2015 at 01:29 PM. |
That's not a corvette motor. Corvettes were all built at the same plant, so plant codes were not included in the partial vin. 65 corvette motors only had a sequence number stamped on them.(and the engine ID number)The motor above is from a passenger car/chevelle or El Camino built at Kanas City in 1965.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-11-2015 at 02:49 PM. Reason: spelling |
#13 |
I did not know that about the sequence numbers. I learn something almost everyday on this board.
#14 |
Just to be clear, the sequence number info is only good through 67 on vettes.
CHEVY/GMC VIN DECODERS |
#15 |
So what actually is the point here?
To find any 67 model year 327 engine cast and assembled in 66-67. To find a correct 67 C10 327 regardless of assembly date. To find the correct assembly coded 327 to match a missing original 327 engine with a documented assembly code.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#16 |
just to help me, who is no good at deciphering engines on my endeavor of finding a 1967 327 hopefully out of a truck but doesn't need to be. And I got the rest of that code off of that 327 I found..
#17 |
#18 |
F = Flint
09 = September I6 = 16 = 16th of September EB in 1965 = Chevelle, 327cid, 300 hp, manual trans, 4bbl carter, RPO L-74
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-12-2015 at 08:25 AM. |
#19 |
so this motor has no crank in it and i found a small journal 327 steel crank thats been turned 10/10 the guy said.. he wants 75 for the crank what are your guys's thoughts on that?
#20 |
Aren't they all?
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#21 |
OMG that's funny. You got me laughing out loud on that one. Yes, they all are. Too funny.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-12-2015 at 12:53 PM. |
#22 |
67Chevy_hotrod, This motor is a 1965. Aren't you looking for a 1967? If you go with the 1965, it's going to need a complete rebuild right? If so, that's going to get a little pricey. Why not hold out for the 1967, or for the money you could just drop a crate in there, and come out a grand or so ahead. If you really want a 1967, keep looking, they're out there.
If you continue your search for a 1967 block, try to get all the block info before you post it up. I will keep this thread marked so I'll see your questions as soon as you ask. Here is a breakdown of the numbers on a 1967 block. There are 3 numbers that you will want to get. Sometimes you can get a definitive answer from just one number. Sometimes it takes two numbers to get a definitive answer and sometimes it takes all three. The partial vin is the fourth set of numbers, but partial VINs aren't found on truck motors till the mid seventies. So a 1967 truck motor won't have a partial vin on it. The three numbers you should be most interested in are: 1. The casting number, You already know about this one. 2. The engine ID number, F0916EB This number consist of 3 separate codes. The first letter is the engine assembly plant code. Your 1967, 327 will be either a F or V. The next 4 numbers are the date of assembly code. It does not include the year, just the month and day of assembly. (I was often used as a 1) 09=September, 16=16th day of Sept. The last two letters are the application code. EB in this example. This code is the most useful, It will tell you the engine size, horsepower, trans type, carb type, vehicle type and smog equipment, if applicable. Application codes were reused over several years, so the block date code is often needed to decode it correctly. In 1967 application codes were two digits. The engine assembly plant code+the assembly date code+the application code make up the Engine ID number. This number is stamped not cast. 3.The block date code. The block date code is cast into the block(opposite side from the casting number) and should precede the assembly code by at least 1 day. I have found 2 to 4 days to be the norm, but as long as the block date code precedes the assembly date code, your good to go. The block date code will be in this format C047(on a 1967 block). The C is the month(March) the 04 is the day(4th) and the 7 is the year(1967). Some later blocks used two digits for the year, but you can usually determine a single digit year from the range on the casting number. With this info you should be able to decode any block you come across. You can use the links in post #2 to decode the numbers you find. The pic in post #3 will show you the locations of the numbers. You can always post your numbers here for a double check. Mechanicalman is better than me, to ask about the small journal. He is a master mechanic and can give you much better advice on the subject of rebuilding, and small journal vs. large journal than I can. Hope this helps if you decide to continue your search. Bruce
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-12-2015 at 01:02 PM. |
