Old 03-09-2015, 12:30 AM   #1
MAC71
MAC71's Avatar
Big Block Motor Mounts
Where do I get Big Block Motor mounts for a 1969 C20 with a 396. Parts stores only have the small block ones and I have been looking on line and can not find the ones for a big block.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 03-09-2015, 01:47 AM   #2
MAC71
MAC71's Avatar
Re: Big Block Motor Mounts
Did some more looking at the small block mounts and now understand what the difference is. The small block only have the rubber linking the engine to the frame where the big block has the bolt go to the plate that bolts to the block. Much stronger but can not find new ones. May have to make the small block ones work.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 02:04 AM   #3
68bowtie
68bowtie's Avatar
http://www.earlyclassic.com/
look for 68-71 motor mounts. part #700697.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 03-09-2015, 02:11 AM   #4
mechanicalman
OK you likely have already seen this?
https://www.rockauto.com/catalog/x,c...69%2BCHEVROLET
https://www.rockauto.com/catalog/mor...836&cc=1031667
Now I don't know if that's an accurate picture/depiction, but it looks different from my small block mounts in my 72. It is application-specific, however I know that does not mean they are what you are looking for.
mechanicalman is offline   Reply With Quote
Old 03-09-2015, 02:14 AM   #5
MAC71
MAC71's Avatar
Found them, thank you. $79 each. Wow
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 02:16 AM   #6
hilandr452
hilandr452's Avatar
I would try a pull and pay type boneyard. They will go cheap and be as good as anything you'll find new.
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 03-09-2015, 02:16 AM   #7
MAC71
MAC71's Avatar
This is what the auto parts store has, but this is incorrect
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 02:19 AM   #8
MAC71
MAC71's Avatar
It's the rubber I need not the stands.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 02:24 AM   #9
MAC71
MAC71's Avatar
68 bow tie found the rubber mounts but at $79 per side I can not do that. I have a set of small block mounts $2.69 a side. Any one use small block mounts. Looks like the driver side will have to be trimmed and I will have to use big washers. Not sure if it will cause the engine to sit to low. The photo is all that is left of my mounts
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 02:25 AM   #10
68bowtie
68bowtie's Avatar
yep they are pricey. you can supposedly make small block rubber mounts work (cheaper) with some oversized washers. there's a thread on here about it somewhere, but i can't vouch for it personally.
Old 03-09-2015, 04:13 AM   #11
hilandr452
hilandr452's Avatar
If you have the mounts and just need what bolts to your engine, I used the later model mounts for an 83 gmc. Added large washer with rubber from a shock mount on the back side I had laying around. I'll get some pictures tomorrow for ya.
Dan Smith
Old 03-09-2015, 07:13 AM   #12
hugger6933
The guy from Texas [whose screen name escapes me at the moment] made his small block mounts work by using big washers. Look in the FAQ section of the home page of this site. Oh yeah, I think TX firefighter is his name.. I remember he does real good work. jim
hugger6933 is offline   Reply With Quote
Old 03-09-2015, 11:03 AM   #13
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'm all eyes and ears for big block motor mounts and stands...I'm dropping a 69 396ci into a 72 C-10 that has the 350/350tb in it now. I really hate to drop $200 in mounts and stands if small block stands can be made to work? Links? Pics? Thanks, ~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-09-2015, 02:44 PM   #14
46stude
Google "POL tubular engine mount brackets 1968-72", if you're not concerned w originality. That's what I plan to use in my 454\TH400 swap in my 350/TH350 equipped '72 Cheyenne.
46stude is offline   Reply With Quote
Old 03-09-2015, 03:20 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Tx Firefighter link:
http://67-72chevytrucks.com/vboard/s...d.php?t=122645
Keith
Convert to disc brakes.
Old 03-09-2015, 03:44 PM   #16
cla511
cla511's Avatar
I have these with the urethane in my 72 and really like them. For a high torque BBC they hold up well.
https://www.performanceonline.com/19...-Brackets-V-8/
1972 C10 Cheyenne 402/TH350
1985 GMC 1500 Sierra Classic 350/700R
1986 K20 427/NV4500
1986 K20 Sub 406/TH400
"Life's tough.....It's enough tougher if your stupid." John Wayne
cla511 is offline   Reply With Quote
Old 03-09-2015, 04:31 PM   #17
MAC71
MAC71's Avatar
This helps. The drivers side small block rubber mount hits the block on the corner but I can cut a 1/4 in off and it will work
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-09-2015, 06:43 PM   #18
Ironangel
Ironangel's Avatar
Awesome! Thanks for the links you guys...
"Two Seventy Two's"
02 3/4 ton Express
Old 03-09-2015, 10:31 PM   #19
hilandr452
hilandr452's Avatar
I ran these mounts with the 454 for about 10000 miles while the engine had a horrible vibration caused by installing the wrong flex plate. They were very solid considering I tried to shake the motor out of my truck....
Mount from Autozone for 1980's BB
Stock BB Mount in my 71
Bolt with rear shock mount washer from a rodeo, very rugged
Dan Smith
