Old 03-09-2015, 10:07 AM   #1
hillbean
What headers to use
Hey everyone so I have a 1960 GMC 1000 with a 73 front crossmember SBC and TH350 for everyone else running this setup what headers did ya all go with. TIA and pictures are appreciated.
hillbean is offline   Reply With Quote
Old 03-09-2015, 11:57 PM   #2
Captainfab
60-66 Nut
Re: What headers to use
Is your truck lowered so that you need a shorty or mid length header? Or will regular long tube headers work?
Old 03-10-2015, 01:00 AM   #3
hillbean
Its going to be lowered so i was thinking shorties or i might just grab a set of ram horns for free
Old 03-10-2015, 09:28 AM   #4
64shortbox
64shortbox's Avatar
What about a set of the new Ram Horn exhaust manifolds with 2 1/2" Collectors? Available through Speedway, eBay, and others I'm sure. Here's the Speedway link
http://www.speedwaymotors.com/Tru-Ra...Iron,3823.html
64shortbox is offline   Reply With Quote
Old 03-10-2015, 01:49 PM   #5
OldGMJon
OldGMJon's Avatar
Question Re: What headers to use
What's a good choice if it isn't lowered Cap't?
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 03-10-2015, 03:50 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
long tube
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-11-2015, 12:33 AM   #7
Captainfab
60-66 Nut
The Hedman #69260's are designed for the '63-'66 trucks with a small block. You can also use the Hedman #69090's and the Hooker #2452's. Those are designed for later model trucks but will work just fine. The 69260's have 1.5" primary tubes and the 69090 and 2452's have 1.625" primary tubes.
Old 03-11-2015, 02:25 AM   #8
OldGMJon
OldGMJon's Avatar
Had any experience with Thorley Headers...Highly recommended here in Cali...
Projects:
65' Chevy Panel swb
Parts:
Old 03-11-2015, 10:07 AM   #9
Mackie
Mackie's Avatar
It depends a bit on what driving you do. Drag strip every weekend = long tube. Cruising and listening to tunes = Rams horns. Then all the choices in between.
Mackie is offline   Reply With Quote
Old 03-12-2015, 01:29 AM   #10
Captainfab
60-66 Nut
No, I don't.
Old 03-12-2015, 08:48 AM   #11
'63GENIII
'63GENIII's Avatar
I've got a set of Thorleys for a BBC. Buddy of mine took them off of his '86 v30 with a 496. They're very well made, tri Y design and worked really well for his truck until he started making over 700hp. He gave me these when he got new custom built ones. I'm going to run them on the L29 FI motor that's going in the '63.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-12-2015, 06:56 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have block huggers on mine and its lowered a bit.. No issues them.
Driverside
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
