Old 03-09-2015, 01:54 PM   #1
1968_long_bed
Unhappy Dang horn
Ok have a horn problem change everything but it continues to go off changed the horn sensor changed the horn assembly changed the wires but when i plug the horns in it keep just sounding getting rather ticked even removed the horn assembly its still going. any advice would be greatly appreciated.
1968_long_bed is offline   Reply With Quote
Old 03-09-2015, 02:18 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Dang horn
Horn Relay?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-09-2015, 02:23 PM   #3
1968_long_bed
Re: Dang horn
the silver square thing with 3 prong about two inches from fuse panel it was buzzing something fierce when i turned on my lights and when it not plugged in no horn sound at all???
Old 03-09-2015, 02:24 PM   #4
1968_long_bed
Re: Dang horn
i said horn sensor before meant to say relay whoops
Old 03-09-2015, 02:47 PM   #5
Longhorn 70
Re: Dang horn
Ah. I thought you meant button. If the wire from the column isn't connected on the relay, does the horn still sound? I think it's a small brown wire on the relay. There is a big red as well as a dark green that goes to the horns. the third wire.....brown?
Old 03-09-2015, 03:59 PM   #6
1968_long_bed
Re: Dang horn
nope it black was brown till i cleaned it off lol
Old 03-09-2015, 04:01 PM   #7
Longhorn 70
Re: Dang horn
no longer beeps with the black (brown) wire connected?
Old 03-09-2015, 05:42 PM   #8
cdowns
cdowns's Avatar
Re: Dang horn
A short in the steering column
Old 03-09-2015, 05:46 PM   #9
Longhorn 70
Re: Dang horn
that would be my guess...
Old 03-09-2015, 08:43 PM   #10
A1971Blazer
A1971Blazer's Avatar
Re: Dang horn
Most likey........the wire in the column that goes up to the horn button simply grounds the horn relay in order to energize it and blow the horn. Check to see if it's shorted to ground when you wiggle around on the steering column harness.
A1971Blazer is offline   Reply With Quote
Old 03-10-2015, 01:58 PM   #11
1968_long_bed
Re: Dang horn
sorry got called into work couldn't finish it up. so ran a couple of leads to the the switch to bypass the black wire. i ( no no random horn sound) already changed out the harness that comes down the steering column. because i had no tail tight flashers (switched to led) and thanks who ever said ground the one that wasn't working. any way now when i check my switch with my light i have no power. at the horn button.
