03-09-2015, 08:07 PM | #1 |
LS swap fuel system
I have a 1983 c10 that I'm putting a 99 LQ4 6.0 in. I've got a tank and sending unit from a 87, and a fuel pump for a 98. The fuel pump has two hoses with it. I know the the 3/8 line is the supply but what is the small one it's maybe 1/8? Do I leave the line off or put it on somewhere?
03-10-2015, 10:17 AM | #2 |
Re: LS swap fuel system
It sound like that 1/4 is the vapor line. I used the 87 sender and I had pressure and return as well as the vapor line. Look in my ls swap link I have the pic of my 87 tank set up going into my 76 that may help.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
03-11-2015, 07:15 AM | #3 |
I was thinking it was the vent line but the sending unit I've got doesn't have a spot for it. The sending units vent line is made different.
03-11-2015, 08:11 AM | #4 |
Gentleman Jim Driver
How about a picture? If its an 87 TBI sending unit, it will have 3 pipes. Supply, return and vapor vent.
FG05M (driver) and FG05N (passenger) for spectra premium brand parts.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
03-11-2015, 10:12 AM | #5 |
yeah that's how the top of mine looks also, the issue is the underside. The in tank pump has two lines I know the one is supply but there is also a small line about 1/8". that's the one that I don't have a connection point for on the sending unit. can't get pictures to load, will try again later
03-11-2015, 01:41 PM | #6 |
Slots go on anything!
You will most likely need to run a new return line. The feed is 3/8, return is 5/16, and vapor is 1/4. You could hook the vent to the smaller line, or run a vapor vent at the top also. The run is relatively small and straight; running new hard lines is pretty easy.
1974 Jimmy- 5.3/4L80e/NP241 |
03-11-2015, 02:03 PM | #7 |
is this what yours looks like? Its an '87 sender with a fuel pump, only one line out of pump.
03-11-2015, 02:04 PM | #8 |
Look on the first page of my LS swap link I have a few more pics of my fuel system.
03-11-2015, 09:30 PM | #9 |
Not sure if these will help but this is what I have
03-11-2015, 09:36 PM | #10 |
One more pic
03-11-2015, 09:40 PM | #11 |
Last one. Thanks for the help
03-12-2015, 10:00 AM | #12 |
I know see what you mean. I think that the extra hose is part of the '98 set up and may be the source of confusion. I would guess that the little hose is some sort of return line that the '98 set up uses.
My pump is out of a recalled ford product that was new and being thrown out. The 'goldish' piece on the sender body looks to me like a vapor separator of some sort.
