Old 08-26-2003, 11:06 PM   #1
RShaips
hooking up MSD ignition ?
My truck has a MSD distributor ,coil and 6AL box ,this came with the truck when I bought it. I have rebuilt the motor and am hooking it all back up. My question is this setup had a condenser on the coil. Do I really need this ? As far as the wireing goes the box has a battery + ,ground ,hot to ignition fuse box,+ and - to the coil and wireing harness to the distributor. Anything else ? Thanks
RShaips is offline   Reply With Quote
Old 08-26-2003, 11:18 PM   #2
LudwigTheMad
LudwigTheMad's Avatar
call MSD tech support, they are great at walking you through what ever you need to know...
Listed in info, or your local msd dealer (parts store) should have the #.
also remember the 6AL has a rev limitter....(sp?) so you "can't" blow the engine.....
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 08-27-2003, 11:09 PM   #3
RShaips
Thanks I'll try them
Old 08-27-2003, 11:11 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Yes you need it!!! HOOK IT UP.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
