Old 03-10-2015, 02:58 PM   #1
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Parting a 72 BB SWB Chassis (not an original BB Chassis)
All,
I've decided to sell my BB Chassis to fund my pending garage build. (this is not an original BB SWB Chassis)
There is a member who was interested in it that I am waiting for an answer if they are getting it. After that answer I will be parting the entire truck in some larger parts.
I rebuilt this chassis 3 years ago and drove it daily as a cleaned up cruiser. At that time I rebuilt the front suspension with all new brakes and shocks (both front and rear) and replaced basically everything in the front suspension.
I removed the body to put it on another project after I rebuilt that frame.
The motor was covered with a very thick tarp since the body was removed and all open holes are covered and ziptied.
The following was replaced at the same time I freshened up the suspension...
New water pump, p/s pump, alt, Stainless Steel P/S lines (from the board) and new gearbox.
It has 72 motor mounts on it as well and the correct 7042208 carb for it as well.
The transmission was rebuilt at that time as well and the truck has 18K miles since the rebuild. The motor does not smoke or have any issues at all.
The brakes are still sealed, working and connected to the master cylinder and the truck will fire with a trigger switch. It has new dual exhaust and there are no leaks on any fluids except the transmission fill tube (seeping) and I will replace that gasket before it sells.
The cab has had the Cab corners and rockers done previously.
Here is the breakdown that I'd like to go with:
Rolling Chassis $750sold
Motor/tranny combo $1500sold
Cab $750Sold
Grill $175
Blue Front end $300
SWB Bed sides $275 and $225
SWB Floor (wavy and a few pits but solid) $300
BB High Hump $90Sold
BB Fan Shroud $90sold
I would possibly breakdown the motor parts later if it doesn't sell complete.
I will not be shipping this as everything is large or heavy.
I can load anything purchased on any trailer you bring.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 03-10-2015, 03:00 PM   #2
Cash3481
Cash3481's Avatar
Re: Parting a 72 BB SWB Chassis (not an original BB Chassis)
Here is the SWB sides.
One is very solid and the other is solid except for the 3"X3" spot pictured in #5.
I can get better pics of anything you need!
Mike
Old 03-10-2015, 03:09 PM   #3
Cash3481
Cash3481's Avatar
Here's a few pics I have of the front end. I can get additional pics tonight!
Mike
Old 03-10-2015, 05:31 PM   #4
Ugly 61
Are the Alt, PS pump and mounts included in the motor price?? If so I'd be interested if you'ld also include motor mounts and frame horns.
Ugly 61
Ugly 61 is offline   Reply With Quote
Old 03-10-2015, 06:59 PM   #5
Cash3481
Cash3481's Avatar
Ugly 61
The motor is complete! Carb to pan. With p/s reservoir, alt and motor mounts.
I can remove it and have it hanging from the puller for loading.
If you need the gearbox that is separate.
Mike
Old 03-10-2015, 08:14 PM   #6
Ugly 61
And the frame horns are they going with the chassis?? I'd also need the big block fan shroud. Do you know if there is any difference between the high hump floor for a 4 speed and the high hump for a BB auto?
Ugly 61
Old 03-10-2015, 08:25 PM   #7
Cash3481
Cash3481's Avatar
Ugly 61
I think you mean the frame motor mounts and clamshells. Yes they go with the motor. I have a shroud and bb high hump. They are different from 4 speed.
Mike
Old 03-10-2015, 08:31 PM   #8
Cash3481
Cash3481's Avatar
Here is the high hump.
Mike
Old 03-10-2015, 08:33 PM   #9
Ugly 61
Ok , I'll take the motor, trans,fan shroud and floor pan. PM with your address and Ph #. If you need a dep. to hold the items I'll send you 1. It'll likely be late next week or the week of the 23rd before I can come down to PU the items
Ugly 61
Old 03-10-2015, 08:36 PM   #10
Cash3481
Cash3481's Avatar
Ugly 61
The 4 speed and bb humps are different by the hole is the only difference.
Mike
Old 03-10-2015, 08:42 PM   #11
Cash3481
Cash3481's Avatar
Originally Posted by Cash3481 View Post
The 4 speed and bb humps are different by the hole isthe only difference.
Ugly 61
Pm inbound!
Mike
Old 03-10-2015, 08:57 PM   #12
nickv6266
nickv6266's Avatar
Mike I'll take the rolling chassis for $750. Thank you.
nickv6266 is offline   Reply With Quote
Old 03-10-2015, 11:29 PM   #13
Cash3481
Cash3481's Avatar
Thanks nick!
You have my paypal...
Mike
