What is it? It came hooked to my 283...
![]() Looks like the numbers on the trani reads 3925660 and the numbers on the bell housing reads 3899621 must not be a truck... ![]()
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
Re: Name that tranny time
Just a hunk of junk muncie m21. Nobody wants them. If you ship it north I'll cover the freight.
It's the least I can do!! LOL!! Look here to decode it. http://www.camaros.org/drivetrain.shtml#trans |
I'd name it.....Stuart.
'62 C10 LWB fleet side. 283 w/ a T5 |
What about.....Bob?
#5 | |
![]() Quote:
The M22's always had them so, at any rate, I have close ratio gearing but I will have to open her up to verify by the number of teeth, yes, I said HER, so Stuart or Bob wouldn't fit too well. It has a Hurst Competition Plus shifter there as well. Cool, the guy sold me an engine for less than the value of the transmission and shifter he just threw in... ![]()
meowMEOWmeowMEOW
Eddie Murphy and Danny Bonaduce both are tired of police saying to them "its Name That Tranny Time again guys"....
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#7 | |
![]() Quote:
#8 | |
You could call her Pat!! Works for both genders!! |
#9 | |
meowMEOWmeowMEOW
![]() ![]() Join Date: Apr 2012
Pull the trans off the Bell housing Jon , the input will have rings around it,two rings M20 one ring M21 no rings M22 . Its a 1969 and up vintage trans and you got the good 11 inch 621 bellhousing to !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#12 | |
![]() Quote:
Chevelles, Camaros, and Corvettes but couldn't pin it down. HMMM! another project...
#13 |
That exact bell housing number started in 1967 and was used for many years . It's one of the more popular bells for all muscle cars
#14 |
did chevy have the speedo on the right side?
1961 chevy K10 my build is------------61K10 build |
#15 |
Yes, that started in 1965 through 1969 for sure , after that Im not sure when it changed. All my Impalas had the speedo cable come across the firewall to the passenger side down to a clip welded to the floor to hold the cable, then into the RH side of the 4 speed . Automatics were on the drivers side.
