03-10-2015, 08:47 PM | #1 |
Power Brake Id
What unit is this? Are parts available? Have new master cylinder with cast
number 5472003. Am missing line to prop valve, 3/8 on prop side and 1/2 " on master cyl side, where can I get one? Any help!
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
03-10-2015, 09:12 PM | #2 |
Re: Power Brake Id
Looks like a Delco M booster. Many vendors sell those little brake lines. I bent and made my own but it wasn't easy. I'd never attempt it again LOL
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
03-10-2015, 09:18 PM | #3 |
Re: Power Brake Id
Yeah I thought of bending them or reflange the end of an existing line but they
are steel and not easy to work with..I need to find a vender....
03-10-2015, 09:24 PM | #4 |
Re: Power Brake Id
The problem is they're so short that the little bending tools don't work.
03-10-2015, 09:56 PM | #5 |
Re: Power Brake Id
Looks like a setup from a 71/72 3/4 ton as shown below. However, the unit you show has a distribution block rather than a proportioning valve which is required for disc brakes.
03-10-2015, 10:02 PM | #6 |
Re: Power Brake Id
You can buy replacement lines from inline tube. http://www.inlinetube.com/
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-10-2015, 10:27 PM | #7 |
Re: Power Brake Id
Yes the unit came off a 69 w/drums, ie prop valve, my error.
Hey swamp rat! Been awhile! I will check the tube shop thanks......
03-11-2015, 04:08 AM | #8 |
Re: Power Brake Id
Your welcome!
