03-11-2015, 01:18 AM | #1 |
engine and drive train
I'm new on here. I have a 1970 c10 stepside project. I have a 350 crate engine with a mild cam. Also have a 700r4 Trans with a 2000 stall and shift kit. The rear end has 3.73 gear ratio. Is the rear end a good setup for the transmission or get lower gears?
03-11-2015, 01:20 AM | #2 |
Re: engine and drive train
I think you'll find you and your truck are very happy with that combination, although I'm not sure you need the 2000 stall.
And welcome to the board. |
03-11-2015, 01:26 AM | #3 |
That's how I got it. It's a brand new transmission. As long as it does good on the highway I'm fine with it.
03-11-2015, 08:14 AM | #4 |
Welcome to the site, I think you will be very happy with that combo. Jim
03-11-2015, 09:43 AM | #5 |
Sounds ideal.
03-11-2015, 09:49 AM | #6 |
Welcome aboard! That's a great combo for these old trucks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-11-2015, 09:50 AM | #7 |
I had the same transmission and gears in my last 70 Chevelle behind a LT-1 fuel injected motor. Was real peppy off the line and cruised right on down the freeway without buzzing the motor.
Like was said earlier, the stall might get annoying, but I think you will enjoy the rest. Not the end of the world if you ever wanted to swap anything out either.
"Life is too short to drive a boring vehicle". Later, Wayne |
03-11-2015, 10:31 AM | #8 |
The 700r4 and 3.73's are about as perfect a combination as you will find. I think you will like it just fine.
03-11-2015, 12:52 PM | #9 |
I ran the numbers on the rear end it read TDA which indicates a 3.73 gears. The rest reads 0606W1. I was trying to figure that out but couldn't does it indicates a posi or not?
