Old 03-11-2015, 07:47 AM   #1
chato0824
Arrow right turn signal problem
I have a 1998 2 door Tahoe that is my daily. This morning I was letting the Tahoe get warmed up and was leaving and turned on my headlights and my right front turn signal stays on now. When I put the right signal on to turn there is a quick buzzing sound comes from the fuse box under the dash. When the headlights are turned off the signal works fine. Anyone ever had this happen and if so what was the problem? Thanks
chato0824 is offline   Reply With Quote
Old 03-12-2015, 01:51 PM   #2
HondaMartin
Re: right turn signal problem
It sounds like there is a short it something. Sometimes the headlight wires get hot, and they may have melted just enough to cause the problem, but im not for sure about this.
1993 OBS Chevy SCSB , 88k miles, 4.3 Auto (waiting on a 383 Stroker) "AR-15, Its like Barbie for men!" - Mark Reed
HondaMartin is offline   Reply With Quote
Old 03-12-2015, 09:02 PM   #3
87lm7
I would check your turn signal bulbs, I had a s10 that did the same thing, turned out the park light filament broke in on and shorted to the signal side, put in a new bulb andno more problem
87lm7 is offline   Reply With Quote
