Old 03-11-2015, 02:46 PM   #1
cv65
cv65's Avatar
rag or universal joint
getting ready to do a power steering set up on 65 c10,Ive seen rag joint on most but also universal on some ,any thoughts on this?
cv65 is offline   Reply With Quote
Old 03-11-2015, 03:06 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: rag or universal joint
Depends on your steering column hook up. If reusing a factory setup, you're likely going to use a rag joint. If aftermarket column that is spline, you'll use a u-joint setup. Either works. Rag joint take a little of the vibration out of the steering wheel but has a slightly softer feel versus a u-joint setup which is very direct.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-11-2015, 03:43 PM   #3
doobiebro
doobiebro's Avatar
What chevy_mike says.. Will need to know how many splines are on your gear box you will have to match it up on the rag joint. Usually the universal joint depending on whats on the end of the steering column splined or OD end will fit the collapsable steering shaft. It was alot simpler and cheaper to but the whole kit from CPP. Here is a pic...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 03-11-2015, 04:24 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Mine looks like the picture above. The rag joint and shaft is a $5.00 assembly from a 78-80 Monte Carlo. I cut off the factory u-joint at the top and installed a polished stainless Borgeson joint when I swapped to a chrome Ididit column:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-11-2015, 04:26 PM   #5
forestb
forestb's Avatar
when you used that collapsible steering shaft did you install it so that the shaft can still collapse or did you stabilize it in some way?
forestb is offline   Reply With Quote
Old 03-11-2015, 09:11 PM   #6
dodgiesdad
dodgiesdad's Avatar
I am hoping for the best of both worlds. On my build I used a vibration reducing u-joint by Borgeson along with a collapsible shaft and a regular u-joint on the other end. Now if I just had the paint finished and I could drive it...
dodgiesdad is offline   Reply With Quote
Old 03-12-2015, 09:46 AM   #7
doobiebro
doobiebro's Avatar
Installed it so it can collapse. shaft goes in far and still has adjustment. It also makes it more easier to install...here is another pic..
