Old 03-11-2015, 02:47 PM   #1
Blue97
Blue97's Avatar
Loose wheel bearings
1997 2wd chevy silverado ext cab 4" RC lift spindles
I bought new slotted rotors from R1concepts about a year ago, installed them with all new parts. I noticed a few days ago the wheels had some slop in them so I changed out the seals and bearings . Two days later the drivers side was a little sloppy so I tightened her up . But I did not notice the cotter pin/nut the first time I installed these rotors. I'm beginning to think they sent me the wrong rotors? By that I mean the cotter pin barely fits in the slot. Here are some pics of everything.
top of the spindle.
bottom of the spindle.
bearings just wanted to show the wear.
I'm actually thinking of just buying another set of stock rotors, i did knock the cotter pin inside the slots with a hammer and punch . But I don't ever remember having to do that on these trucks before.
Blue97 is offline   Reply With Quote
Old 03-11-2015, 03:24 PM   #2
iluvmy72
Re: Loose wheel bearings
Are you running any spacers?
iluvmy72 is offline   Reply With Quote
Old 03-11-2015, 03:31 PM   #3
Blue97
Blue97's Avatar
No sir!
Old 03-11-2015, 03:54 PM   #4
iluvmy72
the bearings you had....were they part of the rotor kit or stock? Is there a washer missing?
Old 03-11-2015, 04:18 PM   #5
Blue97
Blue97's Avatar
Stock replacement bearings and washer is installed!
Old 03-11-2015, 08:22 PM   #6
sntrym95
sntrym95's Avatar
Were the bearing races installed in the rotors when you got them or did you install the ones from the parts store? Is that the stock nut on the spindle?
Mike
sntrym95 is offline   Reply With Quote
Old 03-11-2015, 09:20 PM   #7
Jewbacca
Jewbacca's Avatar
I don't think he has the races in.
Jewbacca is offline   Reply With Quote
Old 03-11-2015, 09:45 PM   #8
Blue97
Blue97's Avatar
When i bought the rotors they came with races installed and i ran them for over a year... This time I installed the bearing races and bought new nut/washers... I'm anal about it . I try to replace everything I can when I tear something down . What I'm wondering is if they gave me rotors for a 88-92.
Specs from rockauto.
rotors.
This is for a 90
StyleFull CastTypeHub & Rotor AssemblyDesignVentedStuds5Supplied Stud (in)M14 x 1.5Outside Diameter (in)11.156Nom Thk (in)1.035Min Thk (in)0.972Bolt Circle (in)5Overall Height (in)4.188Alternate/O
And for my 97
StyleFull CastTypeHub & Rotor AssemblyDesignVentedStuds5Supplied Stud (in)M14 x 1.5Outside Diameter (in)11.609Nom Thk (in)1.285Min Thk (in)1.215Bolt Circle (in)5Overall Height (in)4.516
