03-11-2015, 06:44 PM | #1 |
Gone Fishing
Power window motor issue
How hard is it to change out the power window motor or should I change motor/regulator? My pass window wont go up or down and im getting power to the motor but I believe it is bad. Any suggestions?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
03-11-2015, 09:26 PM | #2 |
Moderator
Re: Power window motor issue
It's not that difficult but you have to remove the whole assembly to replace the motor. Since the cost is not much different you might want to just buy the whole regulator/motor assembly and have it ready for the job. This would limit downtime. But if you want to save a few dollars and can have the truck down while you figure out whats bad then just take it apart, and see whats broken and go from there. If you've never done this before, plan for about 2 hours. A seasoned tech can have one in/out in about 30 minutes.
In my shop we usually replace the whole assembly, because it takes additional labor time to swap the motor and much of the time there is a problem in the regulator that messes up the motor, and we don't want the risk of having a "comback". On Rockauto motors are about $40, and regulator/motor assembly about $60. That's Dorman (which are fine). AC Delco costs more.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-11-2015, 09:27 PM | #3 |
i think its tough. havent done it on my 72 but on my silverado its quite easy.
i used this you tube guide on my silverado before. 10mins guide. it took me 2hrs to accomplish it.
thug life! rebuilding my truck sponsored by: Auto Parts Warehouse |
03-12-2015, 01:34 PM | #4 |
Just changed out motor/reg assembly out on '01 Suburban back door a few months ago. Only took about 30 minutes. DO NOT buy the cheap $40 ones, after about 10 roll up/down at the most, it has quit...POS China junk! Spend the extra $ and get a good one.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
