Old 03-11-2015, 09:29 PM   #1
Ewr101
Ewr101's Avatar
Headlight Adjusting
Looking for pointers on proper headlight adjustments. Mine seem to be googlely-eyed... I know it varies state to state but not too much. So how does the majority of you set your headlights up? Thanks!
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 03-13-2015, 10:08 AM   #2
4oldcars
4oldcars's Avatar
Re: Headlight Adjusting
Don't drive at night.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 03-13-2015, 11:08 AM   #3
turp mcspray
turp mcspray's Avatar
One of the factory service manuals has the procedure in it. Basically, from 25' away, pointed at a wall, the center of the light beam (on dim) should be 6" lower than the center of the headlight. Adjust the side to side until it lights up the right shoulder and the right 2/3 's of the lane. Works good if you can find a dark and deserted street.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-15-2015, 09:26 AM   #4
Ewr101
Ewr101's Avatar
Perfect, that's what I needed to know. Thanks!
72 Chevy 2WD Blazer
Old 03-15-2015, 12:54 PM   #5
smbrouss70
smbrouss70's Avatar
I found this document years ago, and have used it many times.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
