Old 03-11-2015, 10:26 PM   #1
66Submarine
66Submarine's Avatar
Top speed with 4.57 gears? Can I drive 70MPH? I think I'm doing something wrong...
I think I must be doing something wrong...my truck doesn't seem to "top out" at 32MPH like it's supposed to.
Going about 70 per GPS in most of the clip (IIRC)...I normally try to go something like 62-65MPH most of the time.
Perception is a funny thing, isn't it?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 03-11-2015, 11:05 PM   #2
joedoh
joedoh's Avatar
Re: Top speed with 4.57 gears? Can I drive 70MPH? I think I'm doing something wrong..
big tires! gotta be something like a 265/70/15 if 3500rpm and 4.56s
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-11-2015, 11:37 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
You must be running 110 octane and nitrous...or yer tach is lying. Heck I got mine up to 4200 in 4th and was still climbing. 3.73 gear. 30 inch tire. Little lighter truck. My 64 GMC should have either 4.10 or 4.57 and I have 31's on it...maybe I'll get a tach and see if it'll get up to 75.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-12-2015, 10:22 AM   #4
vince1
Time to get the right speedometer drive gear.
vince1 is offline   Reply With Quote
Old 03-12-2015, 01:07 PM   #5
jtrichard
if the GPS said 70 average then your speedo is a little fast (smaller tires then OEM?) and i would say you have a V8 tach on your L6 that would put it about 875 RPM slow
jtrichard is offline   Reply With Quote
Old 03-12-2015, 01:26 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
That inline would NOT cruise at 4300 rpm. lol Now put in a different cam and lighter pistons and that'll change.
Old 03-12-2015, 01:55 PM   #7
CdM
CdM's Avatar
this made my morning!! haha. I run 4.56's with my 39.5's on my 64 chev. Perfect gear for me. But like yours my speedo doesn't seem to get it.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 03-12-2015, 03:18 PM   #8
66Submarine
Yeah, 235/85R16 @ 32" and 660 revs per mile
I don't think you should have any trouble getting up to 75MPH. Just don't blow up that obscure V6 or get arrested while making your land speed attempts...lol
It's a trans from a '66 1/2 ton SWB truck; the odometer reads about 10% fast and the speedo reads faster than that. +875RPM would put me at something like 4,400RPM@70MPH with theoretical 5.70 rear gears...lol
Actually, it should run at 4,300RPM. It wouldn't be super happy there, but it would (or should) do it. 4,300RPM @ WOT is actually the upper spec for propping a Mercruiser 165. The pistons are listed at 20.84 ounces in the GM books, which is pretty much the same weight they give for a 283 piston (20.3/20.42).
Glad you liked it.
Old 03-12-2015, 07:02 PM   #9
factorystock
factorystock's Avatar
GMC V6 3/4 tons came with 4.10's standard 4.56 optional, GMC inline 6 3/4 tons came with 4.56 standard. V6's are like diesels, high torque at low rpms. Not designed for excessive rpms, high rpms will destroy a V6. If you want higher speeds, change the ring and pinion to 3.54's.
factorystock is offline   Reply With Quote
Old 03-12-2015, 11:01 PM   #10
66Submarine
Yeah, I have no personal experience with them, but I'd be hesitant to beat on one like I would a 250/350/454, etc. I'd kind of expect them to live at or below rated power RPM, but with how hard to find/expensive parts are I'd try to go easy on them.
On a different note, I'm hoping to see an increase in fuel economy and a decrease in engine speed real soon...
Old 03-13-2015, 12:05 AM   #11
joedoh
joedoh's Avatar
thats funny, I have a 3:73 and I would like to swap in a 4:30 because of the 31" rear tires. I have overdrive but its better to leave in 4th (1:1) unless I am over 75mph, my little 4 banger makes peak torque around 3300.
Old 03-13-2015, 12:55 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Highest recommended RPM for the 305 was 4000 and even that is pushing it. The highest recommended rpm for my 292 was 3600 but I have gotten it to do 5100 though I kept it there for a very short time. Top rpm on an old 5.9 cummins is 3000. lol Talk about a lugger but man some serious torque.
Old 03-13-2015, 12:59 AM   #13
TJ's Chevy
TJ's Chevy's Avatar
Oh it'll do 4300 rpm, but I was meaning it isn't meant for cruising there. Cruising speed for a stock inline is 2000-2500. But I've had mine at 3500 as well for awhile. 2500 is around 60 for me so I'm happy with that. lol I've had mine up to 4000 in 4th and still climbing....but on windy roads....yeah... lol Free way time!
Old 03-14-2015, 01:29 PM   #14
66Submarine
I almost mentioned the 5.9 in regards to piston weights...now that's lot of weight to be slinging around with a 4.72" stroke at 5,000RPM!
Yeah, 4,300 wasn't really where they intended it to run at cruise, but 2,000-2,500 is really more of a modern contrivance...something around 3,000 seems to have been a common deal at a highway cruising speed.
BTW, I got the 4.10's installed yesterday, so I go 66-67MPH at 3,000RPM now...
Old 03-14-2015, 06:53 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Nice, Little slower acceleration now, but better mileage at least and still plenty low for that 250.
Old 03-18-2015, 04:20 PM   #16
blazer-k5
blazer-k5's Avatar
5500 RPM how big is the flame rolling out of the exhaust ports. ahahahah
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 03-18-2015, 04:46 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Couldn't tell...the headers were still on.
