Old 03-11-2015, 11:31 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
going "Pro Street" - the affordable way!
hey guys, long time no talk. Anyway, i visited with a guy on facebook the other night who has pro streeted his truck while still retaining a 100% stock frame. Ive been wanting to "pro Street" my truck for a NUMBER of years, and NEVER had considered this as an option!
It seems like a SUPER solid way to do it without any major frame altering, can be done in a weekend or two, AFFORDABLE! - no need to spend $2,000+ on a rear subframe that needs to be cut and fit to the truck, retain stock width axle etc.
Basically what this process consists of, is simply moving all suspension components to the inboard side of the frame rails, adding a crossmember to weld top shock mounts too, and some other small stuff. Ive asked for more detailed pictures as well as a "build list" etc and parts i may need to buy to make this as straight forward as possible.
Just curious if anyone else here has already done this same process that can chime in or know anyone with this process done to their truck etc. Basically anyone with ANY knowledge on this type of process please give me pros/cons, ideas, suggestions/tips etc. Im hoping to do this yet this spring!
Heres some pictures of how he set everything up and how it looks. Will post other pictures as he send em to me!
Last pic is pretty dark, tried to lighten.
Anyway guys, let me know what you all think about this.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 03-12-2015, 01:47 AM   #2
eager_adventurer
Re: going "Pro Street" - the affordable way!
Looks promising! How much will it cost you more or less?
eager_adventurer is offline   Reply With Quote
Old 03-12-2015, 07:26 AM   #3
Mike C
Mike C's Avatar
No reason it won't work, won't handle as well with the suspension components so far inboard but that's not the point of Pro Street.
Looks like an S10 rear axle rather than the stock one narrowed? Obviously he's not going for big power.... That plus no traction bar of some type (slapper bar, CalTrac) shows this is an "all show" setup IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-12-2015, 07:32 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Another downside to this, is without a step notch,(an really low suspension),... you will have a pretty tall ride height with a 31" or 33" tall Mickey Thompson tire.
Keith
Convert to disc brakes.
Old 03-12-2015, 07:47 AM   #5
ProStreet83C10
Drag Racer
He said its an early 80s camaro Z28 stock width rear axle, and i would be adding traction bars to my setup. However i have an El Camino rear axle, is that same width as a camaro axle or not?
My current tire is a 275/60R15 which is a 28" tire, the tire im going after is a 29x18.00R15 so im only gaining an inch of tire max, and i MAY put a small block between axle and leaf pack to adjust for that
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-12-2015, 10:52 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Only issue I see is the lower shock mount brackets are lower than the scrub line. If he ever gets a flat tire, he'll be dragging those big time.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-12-2015, 11:22 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Obviously from a handling and ride perspective it won't be elegant, but my actual concerns would be; relying on leaf only to center the axle isn't the best idea with that much tire (its gonna wiggle)...and that with that much tire, if its got any balls, its gonna snap that 10 bolt the first few times out.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-12-2015, 12:01 PM   #8
tinydb84
tinydb84's Avatar
I remember seeing an article from the 80's(?) that someone scanned in and posted that did that. I actually thought about doing something like that for a second but decided against it. If you are going for looks I think it would be fine.
David
Instagram: myfabguy
Old 03-12-2015, 12:07 PM   #9
lolife99
lolife99's Avatar
I agree on the wiggle.
My buddy built a truck like this and it was a handful when you got caught in the rain.
The standard Mickey Thompson tires are so hard, I doubt you will ever hook those.
Keith
Old 03-12-2015, 12:25 PM   #10
SCOTI
SCOTI's Avatar
Even w/a 'better' suspension, those tires are a handful in weather conditions. Hydro-planing (sp?) is common on wet roads w/that much width.
Relocating the leafs inboard is an old-school approach to get the look of pro-street.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-12-2015, 08:22 PM   #11
Mike C
Mike C's Avatar
Originally Posted by ProStreet83C10 View Post
He said its an early 80s camaro Z28 stock width rear axle. However i have an El Camino rear axle, is that same width as a camaro axle or not?
The El Camino rear will be a 7 1/2" ring gear as well. If from a Camaro it's an '82 or up. Only the Hurst Olds and the Grand National came with the 8.5" 10 bolt that's moderately stout. The Camaro rear is either a 7 1/2" or 7 5/8" and inadequate for any real power.
Tire width also plays into the equation, not just height. Swapping the leaf springs inboard and running CalTrac bars with a narrowed rear of some real strength and you're GTG.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-12-2015, 08:24 PM   #12
Rod Run
Rod Run's Avatar
2 friends of mine have done exactly the same thing as you are talking about. One with a 71 GMC and the other with an 85 Ford step side. They both have owned them for years and drive the piss out of both of them.
It seems a lot of people in this thread are just missing the point of your question and are just commenting against pro-street in general. That is a perfectly acceptable way to do pro-street on a budget
Of course you lose a lot when you do something like this, but everything we do has pros and cons
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-12-2015, 08:28 PM   #13
Mike C
Mike C's Avatar
I considered it for my '69 but just don't want to modify the inner bed sides. (stepside leaf spring short bed).
I don't have any beef with the ProStreet thing or with the leaf spring setup. Just that a 7 1/2" or 7 5/8" F-body axle is insufficient for an F-body much less a 1/2 ton truck with 29x19 tires.
Oh, and I wound up with CalTracs on my truck which had spring wind up issues with the 307 in the front and the 3.07 in the rear...
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-12-2015, 09:27 PM   #14
ProStreet83C10
Drag Racer
OK so what would you recc I do for additional support for axle? I just have a mild small block in it for now. Not concerned about snapping axle at this point.
That's a solid point however I try and keep truck out of rain as much as possible. Tires I'm looking at are sportsman pros.
I know. What I'm going for right now is the look. I'm only powered by a mild small block at this time.
I'm pretty sure my axle is an 8.5" axle. I also know its a Camino axle. Maybe someone put bigger ring gear in it when gear swap was done? How does tire width also play into equation. Never thought about width.
Thanks for reply man. I try n drive mine every weekend. What do you mean by "you lose a lot when you do something like this". What's to lose haha
Like I said earlier I Believe my truck has an 8.5" ring gear but I'd have to double check. I also intend to install some traction bars as well.
Thanks for the replies guys. Keep em comin!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-12-2015, 09:59 PM   #15
earl84
I have absolutely nothing technical to add, but, DAYUM, that just looks bada**. Sounds like if you're going for the look, it's great, but there are tradeoffs in performance. Sounds like compromise will be worth it, as long as you are willing to accept the tradeoffs. No different that frame draggin' airbag setups, which I also think look bada**.
earl84 is offline   Reply With Quote
Old 03-13-2015, 08:19 AM   #16
Mike C
Mike C's Avatar
I assumed your El Camino axle was a G-body (78-86) but now that I think about it, it could be older and that means 8.2" if 1960's to early 70's or a 12 bolt if a big block truck, or 8.5" '73-77.
The width of the tire also adds rubber to the ground increasing traction and load on the axles, and really wide tires tend to scrub on turns increasing load on axles and differentials.
My K30 dually (similar effect to really wide tires) with a LockRight in the rear is really rough in the slow turns, even in the dirt.
No matter, to do Pro Street correctly (IMO) requires a narrowed axle housing. Obviously, looking at the truck above, you can do it other ways. Just not a good long term strategy.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-13-2015, 10:17 AM   #17
Rod Run
Rod Run's Avatar
You lose the ability to look like a lot of the other trucks. LOL!!
Old 03-13-2015, 01:53 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Add a Panhard or a Watts link to help control axle movement.
Old 03-13-2015, 11:31 PM   #19
ProStreet83C10
Drag Racer
im just going for the look right now, as my big block wont be built for a LONG time yet, once that gets built i will convert it over to coils, 4 link and a 9". I also plan to add a traction bar of sorts, whether a slapper style bar or similar.
gotcha!
will definitly look into and consider that, thanks for the idea man!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-14-2015, 01:50 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
For example here's a watts link that attaches to the third member cover. If something like this fits your case, it would be an easy way to help it out. Just be careful that the inboard leafs and the watts don't cross-paths.
Old 03-14-2015, 02:12 PM   #21
Rod Run
Rod Run's Avatar
All of these other suggestions are taking away from your "affordable" build.
Also, I don't think I've ever seen a panhard bar in that situation.
If it was me, I would just stick to the set-up that you posted in your original pics and wouldn't even add the traction bars.
If you're going with the look of Pro-street set-up, traction bars take away from it. The whole thing about Pro-street, is that the big meats are supposed to give you all the traction you need.
It is your truck, so have fun with whatever way you choose, but since you asked for different ideas and advice, I figured I'd just throw my two cents in because I have a lot of friends that have done this type of stuff over the years (with me helping them on more than a few of them), so I have seen a lot of the things they came across.
Good luck with your project!
Old 03-15-2015, 01:45 AM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You mean in a leaf spring vehicle? The above is a watts link, but either can be fit with a couple of brackets. Guys on the mini truck forums have built watts and panhard setups for under $150, waaay less if you can harvest something from a junkey.
Old 03-15-2015, 11:19 AM   #23
Rod Run
Rod Run's Avatar
Q
Yeah, I don't think I've ever seen a panhard in a leaf spring vehicle?
I know about the watts link, because I was thinking about installing one in my Camaro at one point in the past
Building a watts that cheap is pretty impressive, but the OP is asking for cheapest way and in his words, "make this as straight forward as possible", so fabbing something like that might be more than he wants to do
Old 03-15-2015, 01:15 PM   #24
smbrouss70
smbrouss70's Avatar
Leaf springs have been controlling side to side movement for well over a century with out the addition of a panhard bar or watts link. The panhard bar will actually cause binding in the suspension due to the fact that it will "try" to push and pull side to side on the axle and the leaf springs will not let that happen. The Watts link would not cause binding, but would be useless due to the leaf springs already doing that job and would be a nightmare to package it with the leaf springs in the way, especially once they are inboard of the frame rails.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-15-2015, 02:04 PM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Q
I'm not making it up for fun (I'd be more creative).
