Old 03-12-2015, 06:05 AM   #1
Thiessen1960
1960 235 to T5 tranny swap
So I have a few questions for the 235 to T5 transmission swap.
1. Do you need to have a clutch reservoir for the transmission?
2. What was the cheapest brake boosts upgrade for having a clutch reservoir if that's the case?
Just wasn't able to find these answers anywhere online. Thanks.
Thiessen1960 is offline   Reply With Quote
Old 03-13-2015, 01:37 AM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 1960 235 to T5 tranny swap
Are you converting to hyd clutch system just to run the T5?
Heres the easy way:
http://67-72chevytrucks.com/vboard/s...d.php?t=644565
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-13-2015, 02:13 AM   #3
Thiessen1960
Ah so using the jeep input shaft after trimming the collar means everything stays exactly how it was then. And no I wasn't trying to convert, I just didn't know if I needed to use a hydraulic system for the T5 which I see no one has mentioned.
Old 03-13-2015, 02:33 AM   #4
Captainfab
60-66 Nut
The '60-'62 trucks originally had a hydraulic clutch, if you don't want a hydraulic clutch, you will have to fabricate up some sort of mechanical linkage or a cable operated clutch. It doesn't have as much to do with the transmission as it does the truck itself and the bellhousing you have. Your clutch fork is on the passenger side which makes it difficult to fabricate a mechanical linkage.
Old 03-13-2015, 07:33 AM   #5
Thiessen1960
So despite it being more expensive it's easier to put the modern hydraulic system in probably then trying to modify everything.
Old 03-13-2015, 05:19 PM   #6
Wrenchbender Ret
Your present system will work fine.
Wrenchbender Ret is offline   Reply With Quote
Old 03-13-2015, 05:46 PM   #7
Lugnutz65
Lugnutz65's Avatar
I'm not entirely sure I am grasping what you are trying to do. So I have to ask a few questions.
1. Does your truck currently have a hydraulic clutch?
2. Is the clutch fork on your current bell on the PS or the DS?
A T5 will bolt up to a 60's Chevy truck bell as long as they both have the same bolt pattern - a Muncie pattern. Like Captain Fab said, the 60-62 truck bells used a hydraulic clutch system that has a fork on the PS. A T5 should bolt up to that just fine.
I recently documented my T5 installation. I included virtually every step from the crank to the rear diff. Mine has a mechanical clutch linkage like those found in 1963 - 1970's trucks. Here's the LINK to my installation. I hope it helps.
I'm interested in helping but I might need more info.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-14-2015, 01:12 AM   #8
Captainfab
60-66 Nut
The kit that I make and sell is for upgrading to power brakes. If you are going to stay with manual brakes, just keep your original combo master cylinder, or replace with the same if necessary. The original combo master will not work when converting to power brakes.
