Old 03-12-2015, 10:35 AM   #1
ubtripn
ubtripn's Avatar
Willa set of stock Tahoe.Yukon Rims Fit
My 69 6 lug original drums?
ubtripn is offline   Reply With Quote
Old 03-12-2015, 11:38 AM   #2
Lattimer
Lattimer's Avatar
Re: Willa set of stock Tahoe.Yukon Rims Fit
I think the center hole on later rims is smaller. They may not fit without some work.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-12-2015, 11:45 AM   #3
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
They wont fit, the hub bore isnt large enough
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 03-12-2015, 12:20 PM   #4
hugger6933
Are you talking steel wheel or alloy Cause I've seen the steel wheel on several trucks. I too have both 16 and 17 inch alloy wheels I had thought about trying on different projects.
hugger6933 is offline   Reply With Quote
Old 03-12-2015, 04:10 PM   #5
ubtripn
ubtripn's Avatar
Thanks all, they are alloy so I think I am out of luck.
Old 03-12-2015, 04:15 PM   #6
Bagd72Chevy
C10 Collector
Steel or alloy doesn't matter the hub bore is too small. I turned down the hubs on my rear axles to bolt them up but they are also the wrong offset and a 1.25" spacer will make them fit well. The 6 lug axles are narrower than the 5 lug. For the front a 1/2" spacer will allow the wheel to clear the hub. You will need the Dorman extended studs for the front.
///Ryan
1971 Blazer - Rusty
