03-12-2015, 12:07 PM | #1 |
positraction help
i need help buying the right size differential for my truck. i have a 12 bolt open differential right now. i want a 12 bolt limited slip but dont know what to buy.
03-12-2015, 12:09 PM | #2 |
Re: positraction help
does the spline have to do with the axle as well?
03-12-2015, 03:25 PM | #3 |
the spline count is how many grooves are in the inside end of the axle shaft where the shaft meets the carrier. as far as axles if you cant find a posi 12bolt that is set up for your truck it might be cheaper to just change the carrier to a posi unit in stead of buying a whole new axle just make sure the spline count on the new carrier is the same as you have now.
