![]() Join Date: Dec 2012
Has anyone tried one of these boxes under the seat?
Found this on eBay. It looks like it may be a good solution. Just curious if anyone has tried one. Length: 26-3/4" End to end. Depth: 12-1/2" Front to back. Height: 4.5-6.125" At one time I had 2 8" boxes under my seat that fit well but they were stolen while it was at the paint shop. They worked well but the bass was a bit muffled.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 03-12-2015 at 01:03 PM. |
Re: Has anyone tried one of these boxes under the seat?
Will work well with a DD sl7
OK I'll bite, what is a DD sl7 please? Is that the old Technics turntable?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I'm hearing no one has tried one of these....
Are there better underseat boxes??
#5 | |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
AHA it took me a while to find what a DD SL7 was.....
DD Audio SL7(10 or 12)Google search plus searching on DD's site. That does look like a great driver. I was thinking more of Pyle Audio or Fosgate.... I don't have the budget for a $400 sub plus box plus .......... Maybe I should have structured my question better. Will these boxes fit under our stock seats? Do they perform well with moderate drivers?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 04-08-2015 at 01:22 PM. |
Also wondered what could be used under the seat. I like this idea and put amp under other side.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
I'm sorry I had just seen your reply.......
May seem kind of pricey but with normal shallow mount subs you will get a kick but the range will suffer because of the lack of suspension travel, also ferrite magnets tend to be huge in order to make the motor force needed where is neodynium can be just a fraction of the size and produced the same amount of power.
the sl is inverted but has full travel for sound while using neo for power |
#10 | |
is the Fosgate OK?
Sundown Audio has some great small enclosure subs as well. For half the price of the DD Audio.
http://www.sundownaudio.com/index.ph...-3-series.html Im running an Sd-2 10" in my 65 Nova and people don't believe its a single 10 til they see it. Fosgate is starting to fall behind unless youre paying for their high end. As mentioned Pyle is just that..... |
#13 |
Kenwood Excelon kfcxw1000f or the kfcxw1200f depending on doing 10 or 12 inch woofer best bang for the buck I sell hundreds every year
#14 |
Historically I use small rectangle box type outdoor speakers under the bench seats of my old trucks. You can screw the brackets to the floor and point the front of them toward your feet. A couple of these with an amp and your ears will be ringing worse than they already are... if your old like me. Plus I like to keep the old radio in dash and mount the new fangled one as an auxiliary under the dash... you know like you used to do with the old CB radio. Because I now view all new electronics as a disposable flavor of the day. I like radios because I like to listen to the news.... keeps my dander up!
White K20 |
#15 |
meowMEOWmeowMEOW
I'm sure you guys considered this, but the reason that under seat boxes sound muffled...is usually the seat
It sounds dumb, but not only does it directly block the path of the outgoing pressure waves, but it can block full excursion of the woofer if the sub is too close to the droop of the seat bottom. Its like listening to headphones through a hat/hoodie. I've always tried to opt for a behind seat or console box. They both can suffer from muffling too, but usually you can aim them in a way so they have at least a somewhat clear path. A ported box and subs that like porting will give you more sound with less physical volume if calc'd correct. I've seen some guys space their seat up slightly, then build a larger enclosure for sealed or in-firing subs.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#16 | |
#17 |
I would love to see that speaker box King-918,
Because that would mean all the air would come out the middle which means big boom. Lol |
| Bookmarks |
