Old 03-12-2015, 01:41 PM   #1
MWHurt
250 Exhaust/Intake Manifold hardware
I'm looking for new mounting hardware for my intake and exhaust manifolds. I've got a 67 c-10 with a 250 (non-integrated cylinder head) and 3 speed Saginaw. I've searched the typical parts stores and I get some very confused looks from the children working there when I tell them I've got a 250. Does anyone know a good resource to identify the exact hardware that's on it before I have to take my daily driver apart and buy the hardware individually? I'd like to have them all on hand before I re-seal this thing. Thanks!
MWHurt is offline   Reply With Quote
Old 03-12-2015, 01:51 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 250 Exhaust/Intake Manifold hardware
Try this one.
http://www.langdonsstovebolt.com/
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-13-2015, 01:31 PM   #3
Scottcoda
Scottcoda's Avatar
I replaced my exhaust bolts with studs threaded 3/8-16 on one end and 3/8-24 on the other.. My studs also had a recessed hex head on it so it was easy to reinstall.. The 3/8-16 goes into the block .. The advantage to this is your not fumbling with your intake and exhaust manifold while trying to bolt them in... Install the studs.. Hang your manifolds on then tighten your nuts.. If your look at the picture below and zoom in you can see the first stud on my manifolds.. Just to give you an idea.. If your looking to be more stock and want to keep the manifold "clips" your gonna find them in eBay or a junk yard.. They are not sold anywhere that I know of .. Good luck with your build
68 GMC 2500 stepside LWB 250CI
Scottcoda is offline   Reply With Quote
Old 03-13-2015, 07:16 PM   #4
lowbucktrucks
if it helps anyfactory part # for stud is 3798281, part # is different for 68
part #'s come from gmc master parts book, may be different from chevy
lowbucktrucks is offline   Reply With Quote
Old 05-15-2020, 05:29 PM   #5
tx71smallblock
tx71smallblock's Avatar
How long are the threads on each side? They sell alot of different 3/8x16 to 3/8x24 studs
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 05-15-2020, 10:52 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I think I have a complete set of factory hardware I will look on Monday and get back to you.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-16-2020, 01:15 PM   #7
RichardJ
http://67-72chevytrucks.com/vboard/s...ud#post8077723
Scottcoda, when I take a close,expanded look at your picture it looks like you still have the short, locator studs in the end holes of your head. Those should usually be replaced with longer threaded studs when using tube headers.
As in the link above, the heads originally had threaded studs in the 3rd hole in from each end of the head.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-19-2020, 03:57 PM   #8
70STOVEBOLT
I do not have a full set of hardware.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
