Old 03-12-2015, 03:23 PM   #1
Aruba1
NV4500, SBC, 4:10 and MPG
Currently I have a 1972 C20 with a 1989 C3500 front end and a 4:10 rear end. The tires are 225/70/19.5 (dually). The motor is a 383 SBC bored over 30 with a holley carb. It has a low cam (not sure of the numbers), stock manifold and dual muffler.
Now I am running a TH350 but my plan is to do a lot of heavy towing. The tranny is excellent shape now so I want to go ahead and install a NV4500 gearbox before I mess it up. What sort of mileage will I be seeing with this gearbox? I am no longer a pedal to the metal person .
Thanks for your help.
Aruba1 is offline   Reply With Quote
Old 03-12-2015, 03:37 PM   #2
steelhorse
steelhorse's Avatar
Re: NV4500, SBC, 4:10 and MPG
I am thinking 8-12 mpg.
steelhorse is offline   Reply With Quote
Old 03-12-2015, 03:41 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I'm thinking a little more than that. What ever you get it will be easier on the engine....
LockDoc
Leon
Old 03-12-2015, 04:23 PM   #4
Longhorn 70
Longhorn 70's Avatar
First the with TH350 you'll have around a 20% loss in drive train. Second TH350 is 1:1 final drive.
NV4500 has 15-17% loss so you get a small gain. NV4500 also has 1:.73 final drive as well as a deeper first gear. Take off whilst pulling should be more effortless. Cruising down the freeway with the overdrive should give you the ability to have better economy by working the engine less.
You may have to find how it "likes" to be driven to get the best performance.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-12-2015, 08:19 PM   #5
Aruba1
WOW, I was hoping for 16-20 mpg, lol. Thanks, I will be going this route anyways so it can be easier to pull the weight. :-)
Old 03-12-2015, 08:36 PM   #6
hugger6933
A 20MPG 3/4 ton? We can all dream. The overdrive is def gonna help but not that much, But your drive train will seem to be in less strain all the time. Jim
hugger6933 is offline   Reply With Quote
Old 03-13-2015, 09:56 AM   #7
My '72 K2500 350/TH350 4.10 235/85-16s truck gets 12.5 mpg. The '72 K/20 I had with SBC400/4spd 4.10 315/75-16 truck got the same. I am sure the NV4500 will get you a good bit better than that with a well tuned motor
