Old 03-12-2015, 07:10 PM   #1
Omana2015
Loud grinding
I bought a 1995 k1500 last night ran great till this after noon I got a loud noise kinda like a grinding metal the sound is extremely close around the ac compressor the brake system light came on as well don't know if that has todo with anything I haven't drove it I fear of breaking anything
Omana2015 is offline   Reply With Quote
Old 03-12-2015, 09:07 PM   #2
rickpilgrim
Re: Loud grinding
Grinding sound by AC usually means either AC compressor clutch bearing or idler pulley need it with bad bearing. I doubt that the brake light has anything to do with it, brake light usually means there's an imbalance between front and rear brake system and that's a leakage problem.
Of course my 98 has a "loose" e brake pedal that drops down and turns the light on so check that first
rickpilgrim is offline   Reply With Quote
Old 03-12-2015, 10:08 PM   #3
Omana2015
Re: Loud grinding
Okay thanks that what I thought it was but wantes to make sure but would air in the system also cause this light to go on??
Old 03-12-2015, 10:18 PM   #4
rickpilgrim
Re: Loud grinding
Yes, air is compressible, fluid is not so it would shift the balance and turn on the light.
