![]() Join Date: Feb 2009
Brake Booster Rebuild or Exchange?
Which is best way to go? Have a 69 Delco M drum unit to replace standard
brake master cyl. If I go with rebuild kit then how hard is it to get disassembled? And who has parts? If I exchange then where is best place to purchase. Already have new Delco master cyl. Also made new lines for same.
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
Re: Brake Booster Rebuild or Exchange?
Send it out to booster Dewey at power brake exchange in Portland, Or.
http://boosterdeweyexchange.com |
I had an original done at BrakeBoosters.com after the reproduction/replacement unit was unusable. In this case he even supplied the core because I didn't have a good one.
He took care of getting the case polished (lots of work, don't plate without doing it, no point) and replating and rebuilding and what you see here is what came out of the box. Ignore the MC lid, that's my horrible fake plating job, not related to them.
![]() Join Date: Mar 2014
Is the truck a daily driver or a show truck? for a daily driver I'd go to Auto Zone or Advance. they're in stock to fit the 72.
#5 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
better to leave the rebuilding of the boosters to people that do them, these are under spring pressure, and if you don't have the correct tooling to hold/capture these, the parts will be launching at you at a pretty good velocity, I wouldn't want one coming apart at me, be safe, don't try it at home.
Have a good one! Ben ![]() |
Years ago I opened one up to see what's inside. Luckily the half that wasn't in the vice flew across the shop and three stalls over put a pretty wicked dent in the side of my 1969 RS/SS 396 Camaro, I think about a thousand dollars damage.
Why do I say luckily? Because if that think would have hit me in the chest, I think it would have killed me. Do not play with them.
#8 | |
If it interchanges and fits, I don't see a reason not to go parts-store. But when I did it didn't fit.
#9 | |
