Old 03-12-2015, 07:27 PM   #1
Dentguy
Dentguy's Avatar
What ECE drop do I have? Trying to distinguish it???
I bought the truck with ECE components on it already. Got spindles in the front and what appears to be there springs as well. Rear has shock relocate kit and ECE plate and springs also.
BUT I'm really not satisfied with the ride. It's got kyb shocks and it should be better than this.
My goal is to be another inch lower than present. Tops of tires at bottom of fenders.
I WONT BAG IT- want to stay daily driven and static.
Opinions please.
What drop is it?
Best way to get another inch lower and great handling and ride qualities.
Thanks guys!
Dentguy is offline   Reply With Quote
Old 03-12-2015, 07:33 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: What ECE drop do I have? Trying to distinguish it???
Either a 4/6 or a 3/5.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-12-2015, 08:17 PM   #3
Mike C
Mike C's Avatar
What size tires are you running. How about some pictures of A-arm angle and trailing arms?
Probably 4.5"-7"?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-12-2015, 08:32 PM   #4
Dentguy
Dentguy's Avatar
255/40/20
295/40/20
Old 03-12-2015, 08:33 PM   #5
Dentguy
Dentguy's Avatar
A arm angle
Old 03-12-2015, 08:34 PM   #6
Dentguy
Dentguy's Avatar
Front end
Old 03-12-2015, 08:35 PM   #7
Dentguy
Dentguy's Avatar
Spindles
Old 03-12-2015, 08:37 PM   #8
Dentguy
Dentguy's Avatar
Out back-
Sorry pics are turned! Just flip your monitor on it's side. Ha
Old 03-12-2015, 08:54 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
You would be surprised how much better it will ride with 15" wheels.
I think a lot of your poor ride quality is in your 40 series 20" tires.
But I wouldn't switch to 15's.
It's part of running 20's.
Keith
Convert to disc brakes.
Old 03-12-2015, 08:55 PM   #10
lolife99
lolife99's Avatar
Some say the new shocks from Ridetech are really worth their high cost.
You might look there first.
Some are hard core Bilstein shock fans.
Keith
Old 03-12-2015, 09:07 PM   #11
Dentguy
Dentguy's Avatar
I just pulled a shock. THEY ARE WASTED! Won't even return to full extension. That answers one question. Guess I better shock shop. But again the stance on this is not exactly where I want it.
I guess I could block the back 1" and look for shorter springs up front. But the rear already rides kinda $hitty.
Old 03-12-2015, 09:07 PM   #12
Dentguy
Dentguy's Avatar
Lowered front A arms??
Old 03-12-2015, 09:09 PM   #13
lolife99
lolife99's Avatar
no.
Trim 1/2 coil if you want to drop the front 1" more.
Add a 1" block to the rear with a bolt in c-notch.
Keith
Old 03-12-2015, 09:34 PM   #14
Dentguy
Dentguy's Avatar
no.
Sounds about right!
Does anyone make a progressive rate spring? Or a "softer" or lighter weight rear coil?
Old 03-12-2015, 09:38 PM   #15
lolife99
lolife99's Avatar
You might try a Hotchkis rear coil
Keith
Old 03-13-2015, 08:26 AM   #16
Mike C
Mike C's Avatar
Truck looks great IMO, and any lower won't change the look much. It's funny how "low" just doesn't look so much after awhile. I know that's how I feel about my truck.
Mine rides well I think. I have 2 1/2" ECE spindles and 2" springs in front and DJM flip kit on stock HD leaves in the rear. I used KYB front shocks all the way around re-drilling the upper mount in the rear for a more vertical arrangement. My lowering is about 4 1/2" front and 7" rear. Any more would require a c-notch.
I have 27" fire in front and 29" in rear. (yours are 28" and just over 29").
44 Willys MB
52 M38A1
64 Corvette Coupe
