4 headlight setup help....
So its been four years since I've had my truck together. A buddy of mine gave me a factory 4 light core support and matching wiring harness. This has replaced the POS aftermarket core support I had on before I took it apart. I have a few questions about putting it back together.
I have already ordered 8 of the adjustment nuts and screws, and i didnt cheap out and get the dorman brand, they break easily. I am lacking the 4 springs though to hold the lights in place. Does anyone have any pics of which way the square plastic nut goes in the core support, and also where exactly the springs attached? Its been awhile. Also I have 2 good headlights with three prong connectors (2A1), I am assuming these are the main headlights that mount up top? I have one clean (1A1) which is two prong, thinking this is the bright headlight? Thanks in advance guys
84' C-10 Custom Deluxe 97' & 98' C-1500 Silverados |
Parts and more parts
Re: 4 headlight setup help....
The three prongs are the Hi/Lo beams and yes they are on top. The two prong is the Hi beam and they go on the bottom. I haven't got a picture of mine, but if I remember right the springs hook onto the core support in a little divot just behind the light tray. The plastic nuts oare on the outside and above the trays and insert from the front of the core support.
I eliminated the factory style sealed beam headlights on my 4 bulb light setup and put in aftermarket light housings with replaceable high wattage bulbs in them and a seperate wiring harness from the battery. I went for the max lighting that I could achieve for the errant Bambi population, that we have jumping out in front of vehicles in my area. It took a little to figure out the wiring alignment for them all to work, but it can be done.
Frank Last edited by piecesparts; 03-12-2015 at 10:15 PM. |
#3 | |
Yeah I got alot of deer by my house too, I live close to some big undeveloped pieces of land. Louis C.K. has a hilarious bit about hitting a deer in his car, you should youtube it, hahaha.
78K & 79C Jimmys
the stock light buckets have a key in the corner to prevent the bulbs from wrong bulb in.
I pushed mine out and ran low beams low,high high
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
hey guys, got everything attached for now but my headlights wont work. The park lights work though, and only the left turn signal works. I haven't really looked into whats going on, got tired of working on it last night.
Does anyone know off hand what the harness that plugs into the firewall/bulkhead plug on the far drivers side goes to? there is three harnesses that plug there, engine, front lights, and???
78K & 79C Jimmys
Wipers , brake valve, headlights , engine are there some are seperate plugs that lock together.
Wires may move spots too
IDK what year or series truck yours is - but it is a fairly safe assumption that you are asking about the rear lighting group. It is small section (only 4 leads) and transits the FW at the bottom of the bulkhead connection (depending on MY). The fuel tank level sensing lead is included in the engine section of the block (the fuel pump/tank switching power feeds - if applicable - have a dedicated grommet). After being led through the FW, they are then run back to the tanks using the same conduit as the lighting harness. |
![]() Join Date: Feb 2014
Double check all of your ground connections. Those headlights are real funny about working intermittently if at all, if the grounds are good enough.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
#9 | |
Yeah I spent about 15 minutes throwing the front light harness back in there. Im sure i wasnt getting good grounds.....
In stock trucks does the front light harness run on the engine side of the radiator? I seem to have alot of excess harness between the two front amber park lights...
The front lighting harness goes outside of the core support from the drivers side and snakes along the bottom just under the front bumper filler panel.
#13 |
Really? Hmmm... anyone got pics?
#14 |
#15 |
Thanks chengny.....
Looks like you ran out of real estate during a cam swap?
#16 |
Here's a few pics of my truck when I was mocking up a front harness kit for it-
#17 |
Pic of my wiring
#18 |
78K & 79C Jimmys
found some of the 88
I even had enough room to hide/run wire in there for my "deer" lights
