Opinions on different clutch brands
Just like the title says----
There seem to be so many brands and stores for that matter between the Rock Auto to Summit racing to the down the road Auto Zones and every thing in between. I just need a good reliable clutch at a decent price is that so hard to find? I'm not rock crawling,racing or really anything other than driving it. Thanks for any opinions I can get |
Re: Opinions on different clutch brands
I've always had good luck with Luk brand clutches.
Fred 1974 C-20 Fleetside White/Crimson Red 292/SM465 4.10:1 open 1976 AMC/Jeep CJ-5 Lime Green 258/T150 3.54:1 open 1972 C10 Suburban - SOLD White/Medium Spruce Metallic/White Avocado Highlander Pkg 402/TH400 3.08:1 open |
Luk are some some of the best clutches. I myself prefer Centerforce but I push my clutches harder than most in what ever i am doing.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
Just did a price comparison between luk and o'reilly by the time i pay shipping it's about the same price aside from the tax man
I have a Sach's in mine and am VERY pleased! That went in after the center hub sheared off my Centerforce without abusing it.
#7 | |
My bad I guess centerforce is the spendy one |
![]() Join Date: Jul 2000
Hard to go wrong with any brand of OE replacement clutch kit. I have used Luk and Pioneer. Both worked great and never slipped, even behind a semi-hot 327. In fact, I liked them better than more expensive Zoom and RAM street-strip kits, which took a lot of pedal effort.
Make sure to get the proper diameter -- 10.4" or 11", and the correct spline count -- 26 or 10. Check http:www/rockauto.com for a good selection and very low prices, assuming shipping doesn't run the price up too much.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Yes thanks mike that's really what I wanted to know, am I gonna go wrong with a less expensive brand.
I am more than likely gonna grab the set from o'reily's tomorrow, just less hassle than doing the online thing |
Don't buy an off-brand name from one of the cheaper parts vendors, do more research.
My AutoZone clutch lasted one week, and a Centerforce lasted years until the truck was sold. No mercy given ! K30 350ci/350hp 4.56 gears - real worktruck. If you're gonna keep it don't cheap out !
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
Post Whore
![]() Join Date: Aug 2014
I believe a lot is to be said for proper installation, one can poorly install the "best" clutch or not adjust it properly and there goes the whole thing, and I'm sure there are pro shops installing the less expensive stuff every day and doing it right and those clutches last for years, just my two cents
i changed out my stock clutch in '98 with a LUK clutch, i'm still running it to this day, almost 18 yrs
#13 | |
Thats great not sure you can do much better than 18 yrs, and from what I've learned LUK is on the low end for cost. And Greg i think your correct there is a lot to be said about how it's installed |
