Old 03-12-2015, 11:22 PM   #1
jvs99560
jvs99560's Avatar
Removing 1972 C10 Cab
Hello. I have a 1972 c10 with an automatic trans and AC. What do i need to unhook to pull the cab? Im ok with cutting all the wiring. What is the best method step by step process. Thanks
jvs99560 is offline   Reply With Quote
Old 03-13-2015, 06:20 AM   #2
swamp rat
swamp rat's Avatar
Re: Removing 1972 C10 Cab
Best method? Not cutting any wiring! .... There is no real step by step process just make sure everything is unhooked.
Remove battery, negative cable first.
unhook all wiring and label it so you know where it go's later, that includes ground straps.
Drain and remove radiator.
Unhook heater hoses.
Drain brake fluid from master cyl.
Unhook brake lines from master cyl. Do you own flair nut wrenches?
Unhook Linkages from tranny.
Pull steering column.
Pull Seat.
Unhook Gas line below cab.
Unhook E brake cable.
Unhook oil pressure line if equipped.
Remove the front clip.
Removing doors makes the cab lighter.
Unbolt cab mounts.
Now look everything over to be sure you didn't miss anything..
How do you plan on lifting the cab? overhead hoist? Cherry picker?
Here's a thread that shows a 4X4 support mod for a cherry picker:
http://67-72chevytrucks.com/vboard/s...light=cab+lift
Now where are ya gonna put it? do you have a dolly made to put it on?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-13-2015, 11:22 AM   #3
jvs99560
jvs99560's Avatar
Pull Seat.
Unbolt cab mounts.
Thanks for the info. I mentioned cutting the wiring because im going to order a new Painless kit. Im going to use tge cherry picker method i think. Or 5 or 6 buddies haha.
Old 03-13-2015, 12:16 PM   #4
Rod Run
Rod Run's Avatar
Just unbolt everything. It's pretty self-explanatory once you start.
As far as removing the cab goes, me and my brother-in-law just lifted mine up and carried it over the front end of the frame. A completely stripped cab can't even weigh 300 pounds, because it's pretty easy to move
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-13-2015, 12:22 PM   #5
jvs99560
jvs99560's Avatar
Great info. Thank you. Seems like i should pull the motor and trans first. Is it fairly straight forward to remove the shifter from the trans? TH400.
Old 03-13-2015, 01:56 PM   #6
Rod Run
Rod Run's Avatar
Oh ya.... Once you look at it, you will feel much better about it.
I actually pulled my nose and fenders before the engine and tranny. It's much easier that way, since that stuff has to come off anyway. It's kind of like peeling away an onion. You start at the outside layer and work your way to the center
