Old 03-13-2015, 04:05 AM   #1
naphtali5725
naphtali5725's Avatar
electric to manual window conversion
going from electric to manual windows on my 86, wanted to know if anything other than the window regulator is required to make the change...
any insight appreciated...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 03-13-2015, 09:25 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: electric to manual window conversion
the electric window switch hole lines up to the crank nib
burb/CrewCab will have the larger (4) hole.
if it doesn't seal at the top ,loosen the bolts and adjust
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-13-2015, 05:38 PM   #3
naphtali5725
i'm not worried about door panels etc. just wanted to make sure i didn't have to change any other window components except the regulator/handle
My build thread...
Disabled Veteran
