Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-13-2015, 10:41 AM   #1
67JimmyMO
67JimmyMO's Avatar
78 gmc 6500 366 r&r
I am wanting to R&R the 366 in my 78 GMC 6500. Pulled the radiator, exhaust manifolds (left the exh pipes attached), starter, hoses, wires, etc.
Then went to remove the bellhousing-to-engine bolts. There are 7 3/8" bolts that hold the bellhousing to the engine... and it looks like the bottom 2 and the top one are inside the bellhousing, with about 1/2" clearance to the flywheel. I don't think I can remove those 3 bolts without removing the flywheel.
Was wondering...am I going to have to remove the engine/bellhousing/trans as a unit to do the engine R&R? Or pull the trans, then drop the clutch and flywheel out the bottom...then remove the 3 bellhousing-to-engine bolts that are behind the flywheel?
I've done a lot of engine swaps on cars and pickups but not so much on these bigger trucks...this one has got me stumped on the best way to proceed.
1967 GMC SWB 383 Stroker w/Saginaw 4sp
1979 Chev C30 Scottsdale Flatbed 350 4sp
2000 Chev 3500 Flatbed 454 Automatic
1978 GMC 6500 Flatbed Dump 366 5sp + 2sp
1965 Chev K10 LWB 230 4sp
1985 Chev K30 Flatbed 350 4sp
67JimmyMO is offline   Reply With Quote
Old 03-13-2015, 12:30 PM   #2
67JimmyMO
67JimmyMO's Avatar
Re: 78 gmc 6500 366 r&r
With a little more investigation it looks like there is a 1/4" plate that is between the bellhousing and the motor...and may be the inside bolts I am seeing just hold the plate to the motor.
And I think I did find the top bolt on the outside of the bellhousing that I thought was on the inside..
Is that 1/4" plate an adapter plate to allow for a larger clutch possibly?
Old 03-13-2015, 11:44 PM   #3
jumpsoffrock
^I have just found out recently, that that is exactly what it is.
jumpsoffrock is offline   Reply With Quote
Old 03-14-2015, 04:38 AM   #4
mrolds88
Yes. Plate bolts to block and bell bolts to plate. You should have a 13" clutch.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-14-2015, 08:34 AM   #5
67JimmyMO
67JimmyMO's Avatar
Thanks for the replies jumpsoffrock and mrolds88.
Was sure hoping I could pull the engine without pulling the trans or bellhousing, glad to hear that is the case.
