Old 03-13-2015, 02:01 PM   #1
tubbed55
tubbed55's Avatar
original brake pedal spring
does anyone know which one of these springs if any is the original brake pedal spring. Thanks
tubbed55 is offline   Reply With Quote
Old 03-13-2015, 02:18 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: original brake pedal spring
The longer one
dwcsr is offline   Reply With Quote
Old 03-13-2015, 02:36 PM   #3
Russell Ashley
Russell Ashley's Avatar
The larger one is the brake spring, used along with the rod. On my 57 the spring hooks to the top of the pedal above the pivot, the rod hooks to the spring, and the other end of the rod hooks into a hole in the top of the frame rail. The smaller spring might be the clutch return spring.
BTW, The FAM does not show the rod, it shows the brake spring hooked to the rear of the mc mounting bracket, but my 57 had the rod, and there was a hole in the frame in the correct place, so it seemed right to me.
Russell Ashley is offline   Reply With Quote
Old 03-13-2015, 02:51 PM   #4
tubbed55
tubbed55's Avatar
Ok thanks, I bought the dual master cylinder bracket used with original pedal. With spring on, the pedal stops when it hits firewall. The original master cylinder rod has a stop to stop pedal travel. Is just the way it's going to be or am I missing something?
Old 03-13-2015, 05:36 PM   #5
tubbed55
tubbed55's Avatar
Fixed it.....made a metal stop that bolts to the bracket to keep pedal off firewall.
Old 03-13-2015, 06:21 PM   #6
Russell Ashley
If you are using the original brake light switch check to make sure the pedal comes up far enough to turn off the brake lights. If my pedal doesn't come up all the way to the floor my brake lights stay on.
Old 03-13-2015, 06:49 PM   #7
tubbed55
tubbed55's Avatar
I'm running all new brake lines and going to use a inline pressure brake switch. Just wasn't crazy about the pedal hitting the newly painted firewall. with the stop it gave me approx 1/2" clearance. I made it slotted also in case it needs to be adjusted.
Old 03-13-2015, 06:50 PM   #8
OrrieG
OrrieG's Avatar
Also make sure you have the rubber donut around the pedal shaft between the pivot arm and firewall to keep from destroying the firewall mounted brake switch.
OrrieG is offline   Reply With Quote
Old 03-14-2015, 01:07 PM   #9
_Ogre
_Ogre's Avatar
on thing to consider:
those inline brake light switches don't seem to have a good life span
on the other hand... the brake switch in my 58 is the original
and like orrieg states; a proper install the switch does not hit the firewall
if the inline switch fails you'll need to bleed all the brakes
floor board switch failure... 2 screws and 2 plug in wires
shop air compressor timer
Old 03-14-2015, 02:43 PM   #10
OrrieG
OrrieG's Avatar
From 76-2000 as a 7K miles a yearDD I replaced mine once and the replacement still works.
Old 03-14-2015, 04:51 PM   #11
Russell Ashley
Don't mean to drag this thread out or change direction, but according to the FAM the pedal should never hit the floor. The pin in the original mc pushrod has and eccentric shoulder on it and you turn it until the pedal is .68 inches from the floor where the pedal rod comes through. Section 5, sheet 12 of the FAM shows this. I tried to copy it but because of the binding I couldn't lay it flat enough to get the instructions that explain this.
Old 03-14-2015, 06:54 PM   #12
tubbed55
tubbed55's Avatar
That was my point the original m/c has a stop. A dual m/c does not have this stop and does not keep the pedal from hitting the firewall. I got it working with the stop I made. To late for the original switch...firewall was all welded up smooth and painted. Try my luck with the online switch. Thanks for all the help...
