Old 03-13-2015, 03:27 PM   #1
macdodd
rpms = speed
I've got a 350 with 305 heads. At 2200 rpms,,,,shows I'm running 50 mph. Is that about right? Its got the 3 speed trans in it. Lets say I want to go out on the interstate,,,,can I run 70 and not hurt the engine? Thanks
macdodd is offline   Reply With Quote
Old 03-13-2015, 03:38 PM   #2
71K20chevy
71K20chevy's Avatar
Re: rpms = speed
It could be right, depends on tire size and rear gear ratio.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-13-2015, 04:14 PM   #3
SS Tim
SS Tim's Avatar
Re: rpms = speed
http://www.summitracing.com/expertad...tio-calculator
SS Tim is offline   Reply With Quote
Old 03-13-2015, 04:57 PM   #4
macdodd
Re: rpms = speed
Its a '69 chey 1/2 ton pickup. My mechanic says its the stock rearend for that year. 15 inch tires.
Old 03-13-2015, 05:09 PM   #5
71K20chevy
71K20chevy's Avatar
Re: rpms = speed
How tall are the actual tires? Rim height makes no difference in rpm's. Also, is it an automatic or manual 3 speed?
71 K20
64 GMC mud truck
Old 03-13-2015, 05:19 PM   #6
macdodd
Re: rpms = speed
25in tire height,,,,its a 3 speed auto. Thats the next question,,,LOL. It really likes the gas,,,which is expected for the engine,,,could I change the transy out for,,say one with an overdrive in it,,,
Old 03-13-2015, 05:22 PM   #7
71K20chevy
71K20chevy's Avatar
Re: rpms = speed
Using this calculator, I figure you either have 3.08 or 3.23 gears.
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
You could change the tranny out for say a 700r4, but is the expense really worth it?
71 K20
64 GMC mud truck
Old 03-13-2015, 06:23 PM   #8
macdodd
Re: rpms = speed
Yea I think he said a 3.08,,,,,,,, he was surprised
Old 03-13-2015, 06:41 PM   #9
Pop's C-10
Pop's C-10's Avatar
Re: rpms = speed
if you have a smart phone you can dl a speedometer app,,there pretty accurate
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-13-2015, 07:08 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
Re: rpms = speed
The majority of automatic trucks had a 3.08 rear, the majority of the 3 and 4 spds all came with 3.73 or 4.11 (mostly 3.73)... there's a chart somewhere... These trucks went 70 mph just fine when they were new.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-13-2015, 08:08 PM   #11
macdodd
Re: rpms = speed
Thanks,,,,I'll run it for awhile and see ,,,,, LOL,,,,of course,,,I'm not used to the gas being sucked in,,,. but the more horsepower,,,the more gas,,,,and it sure ****s and gits it,,,,LOL,,,,thanks for all the input,,,,,Bill here
Old 03-14-2015, 01:17 PM   #12
macdodd
Re: rpms = speed
Hey,,,,more questions,,,,LOL. At idle,,,I'm pushing about 20lbs of oil pressure,,,at around 3k rpms,,,its steady at 38lbs,,,running 20/50 oil in it. Is this ok,,,,my mechanic says he thinks with the age of the engine,,,,the bearings might be worn,,,says if it goes lower or doesn't stay steady,,,we'll pull the engine and rebuild,,,,
Old 03-14-2015, 02:57 PM   #13
71K20chevy
71K20chevy's Avatar
Re: rpms = speed
I've always heard 10lbs per 1k rpm is acceptable. It could be higher (mine pushes 45 psi at idle), but I don't think it's enough to really worry about.
71 K20
64 GMC mud truck
Old 03-14-2015, 03:06 PM   #14
macdodd
Re: rpms = speed
Thanks,,,,he was more concerned about it staying steady,,,,or dropping out,,,,
Old 03-14-2015, 08:41 PM   #15
outdoorsman310
outdoorsman310's Avatar
Re: rpms = speed
mine has a 350/sm465 4.57 rear and 265/75/16 tires. it used to have 245s and was worse. I usually drive around 75-80
outdoorsman310 is offline   Reply With Quote
Old 03-14-2015, 10:08 PM   #16
macdodd
Re: rpms = speed
Tire on mine are Cooper Cobra,,,,P235/60 R15,,,,LOL,,,,jeeeez ,,,its been years since I drove a vehicle that had some damn horsepower and sound LOUD,,,,and no overdrive,,,,
