US Army Veteran
![]() Join Date: Nov 2008
Front bumper fog lights - help needed!
Hey guys,
Could use some help. Visualize - '72...front bumper...has the orange fog/park lamps. Is it possible to unplug the wiring harness to those lamps? If so, what's the secret? Need to remove the bumper to get fender off for some repair. Common sense says "unplug" the connector on the back of the lamps, but I'm suffering from a temporary loss of cabin pressure on how to get the harness disconnected.
1972 C10 Highlander - The making of a daily driver |
![]() Join Date: Oct 2010
Re: Front bumper fog lights - help needed!
If I remember they will unplug from the core support.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
US Army Veteran
I'll give that a try, thanks for the assist!
Old member
Harness unplugs at support where it goes through.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Should be about 6-8" of wire from the lense to a plug.
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
