Old 03-13-2015, 09:56 PM   #1
v30crewcab
v30crewcab's Avatar
viton valve seals?
anyone have a part # for the viton valve seals that would go on a 80's 350 without machining? the positive seal type is what I'm looking for. I used some I had laying around on another engine, but here wasn't any part # on the package, and I want to put some on my other motor as well. thanks.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-13-2015, 11:03 PM   #2
MikeB
MikeB's Avatar
Re: viton valve seals?
What year engine? Early small blocks need to have the guide bosses machined to accept positive seals. Chevy eventually switched to positive seals, but I don't know the year. I do know they were used by the mid-80s.
BTW, what are the symptoms you're seeing?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-13-2015, 11:27 PM   #3
Motherfrog402
Motherfrog402's Avatar
I can tell you that my '79 L-82 Corvette needed to have the heads machined, in order to accept the new viton seals, so it had to be after that that they changed to the newer style head.
I had my heads done in '97, so I don't remember the part number, sorry.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
1972 C10 Suburban - SOLD
White/Medium Spruce Metallic/White
Avocado Highlander Pkg
402/TH400
3.08:1 open
Motherfrog402 is offline   Reply With Quote
Old 03-13-2015, 11:31 PM   #4
SkinnyG
SkinnyG's Avatar
I didn't want to pay for machining, so I used factory o-rings AND Ford-style umbrella seals.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-13-2015, 11:36 PM   #5
v30crewcab
v30crewcab's Avatar
I put the last ones on a 82ish 305. had to push them on hard but it worked good. it was the kind with the metal ring around the bottom. guess I will do some more digging. not going to machine them I know theres some that fits! just gotta dig up the part#.
71 longbed 5.3 4l80
Old 03-18-2015, 08:08 AM   #6
v30crewcab
v30crewcab's Avatar
looks like sealed power mv-1888 is the individual # for them. going to make sure they fit in a few days. haven't got it apart yet, still working on tower notch and 4link.
71 longbed 5.3 4l80
Old 03-18-2015, 09:00 AM   #7
MikeB
MikeB's Avatar
That's worked well for me in the past. In fact, just the o-ring seals work pretty well until the guides start to wear. However, most people don't understand how to install the o-rings. And of course, the valve stem must have two grooves. Regarding the umbrella seals, I don't remember the type I used, just that they were for 11/32" valve stems. However, if the valve guides are worn and the intake is sucking in air on the intake stroke, then positive press-on seals are the answer, especially for the intake valves.
I once used a Fel-Pro top-end gasket kit for mid-80s 350s that came with 8 positive seals and 8 umbrellas seals. As I recall, the postive seals were for intake, the umbrellas for exhaust.
On a similar note, the postive seals on my new GMPP Vortec heads are different for exhaust and intake. My guess would be the exhaust seal is a little "looser" to allow more lubrication of the guide.
Mike
