power steering is crazy easy.... feels wrong
72 gmc 3500. works better than any vehicle ive driven... sitting still at idle you can turn this thing with a finger nail... it turns so easy it feels like the tires aren't even touching the ground...im tempted to put a stabilizer shock on it... any thoughts?......
Re: power steering is crazy easy.... feels wrong
What is your secret? mine turns pretty good with one finger, I'm happy though. As long as it works good I'd go with it.
72 C10 350/TH350 |
![]() Join Date: May 2001
I have had over 100 of these trucks and some of them steer just like you describe. I have no idea why some are like that. I just sold a 72 C/20 with 42k original miles that had the super easy steering.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
![]() Join Date: May 2010
My 69 has been easy since new. Those were the days of over boosted power steering and very little road feel. Everyone was just thrilled to not have to struggle with steering anymore. I don't know if a stabilizer would help much. Good question though.
The was a sales bulletin tagline. How much effort does it take to sell power steering? Two fingers!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Moderator
![]() Join Date: May 2007
All of the driving trucks I've had with power steering turn effortlessly as you describe. To me it feels better than a modern vehicle.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Mar 2014
I think you may be used to present day "power steering" which requires a good deal more effort than the earlier units. Steering effort in my 2011 Ford Ranger is far higher than in my enormous 1958 Buick Roadmaster. My 1961 John Deere tractor really has "figer-tip steering" and it weighs 6,500 pounds! I guess there's a rationale for this but personally I love the old light-touch units.
Bill Shenandoah Valley of Va 1972 GMC 2500 Sierra Grande 402, Custom Camper Package |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Early power steering was over assisted. You lose the road feel. Some love it some hate it.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
![]() Join Date: Apr 2011
They sell pressure reduction kits that will increase the "feel" if you want. It's an insert you put in the pump outlet. I don't have a link handy but I bet someone here does.
the reason I asked this is it seems to be very easy to over correct after a bad spot in the road... you know, a pothole or bad bump in the road.... was thinking a stabilizer would firm up the steering enough to reduce that from happening. so you guys think i should just drive it more and get used to it?
laying low
![]() Join Date: Mar 2001
Drive the truck everyday. You will get used to it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#13 |
stabilizer in my 4x4 really doesn't help too much at all. it's still way too easy to steer.
#14 |
Eat, Sleep, Drive a Chevy
It sounds like you could have some worn front end parts, you should check the tie rod ends and idler arm for wear. (not the ease of steering but because you mention the over correction when hitting bumps)
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#15 |
![]() Join Date: Nov 2005
Where the pressure line go's into the pump. Remove the large fitting that screws into the pump. There is a pressure spring behind there. This spring is to stiff. You need to find a weaker spring. If you can't find one, as a last resort you can shorten it one coil at a time. You will have to experiment to find the feal your looking for. Just remember the weaker the spring the more effort you have to give to steer the vehicle. Hope this helps!
#16 |
thanks, all
