Old 03-13-2015, 10:25 PM   #1
WarMonger
WarMonger's Avatar
Exhaust manifold
Will these fit on a late 70's 350?
WarMonger is offline   Reply With Quote
Old 03-13-2015, 10:27 PM   #2
WarMonger
WarMonger's Avatar
Re: Exhaust manifold
Sorry attachment follows
Old 03-13-2015, 10:53 PM   #3
71K20chevy
71K20chevy's Avatar
Yes.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-13-2015, 10:54 PM   #4
seattle gmc
seattle gmc's Avatar
yes, hard to tell from the pic but the one on the left looks like there is a bracket on it, or a stain in the concrete??
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 03-14-2015, 05:59 AM   #5
hamjet
hamjet's Avatar
they have quite a dump angle to it, I wonder if they'll interfere with any thing, (Z bar if you have standard tranny) Also I see the heat riser is on the driver side exhaust..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-14-2015, 02:27 PM   #6
slikside
slikside's Avatar
This is the same manifold bolted on the driver side of my '72, but it is not original to my truck.
It is cast right onto the manifold...not a bracket. There is a threaded boss in the forward end of it where the lower (pivot) bolt to my alternator attaches.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 05-14-2015, 10:09 AM   #7
WarMonger
WarMonger's Avatar
If I were to run these Ram Horns, Do I/should I run heat shields for the spark plugs?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
Old 05-14-2015, 10:23 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Those will "fit" any SBC from a 283 to a 400.
I have always used heat shields with manifolds.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-14-2015, 10:57 AM   #9
71K20chevy
71K20chevy's Avatar
My truck had ramhorns with no shields and it never caused problems. But my plug wires were run underneath.
71 K20
64 GMC mud truck
Old 05-14-2015, 11:19 AM   #10
WarMonger
WarMonger's Avatar
Gary
Get them from LMC?
1970 C20
-_--_--_- ______
1972 K5
Old 05-14-2015, 11:56 AM   #11
michael bustamante
michael bustamante's Avatar
those are what were used on the 67 c10`s with a 283. pretty sure they were on the previus years with a 283 also.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-14-2015, 12:16 PM   #12
WarMonger
WarMonger's Avatar
Do I want to use the used ones I found, or should I get some ones from LMC? If I go with LMC, which ones do i want to put on a 383 stroker?
1970 C20
-_--_--_- ______
1972 K5
Old 05-14-2015, 12:36 PM   #13
michael bustamante
you will definatly like the angle dumps better if yours is a 2wd. the straight dumps are more for 4wd
1967custom
Old 05-14-2015, 12:53 PM   #14
WarMonger
WarMonger's Avatar
So just run the ones i have in the pics of the beginning of this thread?
1970 C20
-_--_--_- ______
1972 K5
Old 05-14-2015, 01:13 PM   #15
GASoline71
GASoline71's Avatar
Get them from LMC?
I have only purchased one item from LMC (transmission cooler lines) so I really can't comment to what they offer. I'd just use the ones you have.
Gary
Old 05-14-2015, 08:52 PM   #16
seattle gmc
I have purchased a ramshorn from LMC, and it fit without any issues and sealed up nicley.
Notice that i wrote ramshorn and not ramshorns. I bought the other one from Roc Auto since it was cheaper. That side of the engine is still leaking, and what they sent me was not what was described.
