Old 03-14-2015, 10:28 AM   #1
cmkruse
Question How do I replace the upper bearing in the column?
Well I have it torn down to the bearing and the metal support housing but don't know how to get it off the shaft from there. Any suggestions?
Craig
cmkruse is offline   Reply With Quote
Old 03-14-2015, 11:56 AM   #2
Steve Cole
Re: How do I replace the upper bearing in the column?
You have to remove the bearing housing from the inner shaft. The upper bearing has a plastic race that you can carefully pop out of the steel race by hand.
Steve Cole is offline   Reply With Quote
Old 03-14-2015, 09:16 PM   #3
cmkruse
That's what I thought but the bearing bracket housing doesn't want to slide off the shaft so I can pop the bearing out. I don't see any puller holes like in the steering wheel and I don't want to mess up the outer housing. I'll hit it with some PB Blaster and maybe that will help.
49 Chevy Panel 235 cu in
72 Chevy Pickup 350 cu in (Friends Truck- Why did I volunteer)
Thanks to all the forum gurus for their help past and present.
Old 03-14-2015, 11:11 PM   #4
Steve Cole
Go here: http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Look for this link: 1971 chevrolet 10-30 truck and passenger car chassis overhaul manual. go to page 398.
Old 03-15-2015, 10:54 AM   #5
cmkruse
Talking Re: How do I replace the upper bearing in the column?
Thanks. This answers a lot of the questions I had. I bought one of the 68-72 manuals from the vendors but all it has is a couple of sheets for the 72 and it was just random pages. This is a bunch better manual. I down loaded it and will put it to good use. Thanks a lot for the link.
Craig
