Old 08-27-2003, 12:34 PM   #1
ScottH
ScottH's Avatar
How can u ID a van tilt from a truck tilt once installed?
Picking up a 72 this weekend with a tilt wheel. The column is black with the rest of the interior blue, so I suspect it was installed later on (I know, check the options list, but it was late and I looked quickly at it).
Is there an easy way to tell if it was a van tilt installed vs an original truck column?
Any info is appreciated. Thanks.
ScottH is offline   Reply With Quote
Old 08-27-2003, 12:39 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
I thought you had to drill out a rivet in the shaft and slide it to make it fit and rerivet it. If there's a bolt or crappy rivet job, you probably have a van retrofit.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 08-27-2003, 12:40 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
All tilt columns were black regardless of the interior color, so don't let that be your guide.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-27-2003, 01:20 PM   #4
JimKshortstep4x4
Talking
The surest way to tell is to look at how much shaft sticks out of the column at the rag joint. Trucks have approximately 1", Vans have approximately 5".
Jim
Old 08-27-2003, 07:30 PM   #5
ScottH
ScottH's Avatar
Thanks to everyone for the great info. BTW, Jeff any idea of why tilts were always in black?
Old 08-27-2003, 07:37 PM   #6
rickspickuppart
the shift handles are different (vans don't go out as far as a truck one and has harder bends), a van one won't fit in a truck without shortening the shaft so once it is in and has the correct handle on it they are basicaly the same
rickspickuppart is offline   Reply With Quote
Old 08-27-2003, 07:41 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
My guess is economics. Few tilts were installed and making them all black meant they would "go" with any interior color.
Old 08-27-2003, 10:27 PM   #8
Rod
Real tilt coulmn end shaft length. This one's an automatic but the 4 spd are the same lenght also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-27-2003, 10:30 PM   #9
Rod
And van ones like this have a longer end shaft lenght .. like this column. So there a recognizable difference you can look for without have to look to hard for other differences. Rod
Old 08-27-2003, 10:36 PM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
Here is a side-by-side look.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-27-2003, 11:41 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some of the early van tilts had the exact same shifter, and the older ones also had the 1/2 mool signal plug instead of the flat one.
The best way is the shaft though.
Also on shortening the intermidiate shaft, there is no reason to re-rivit it. It still has a few inches to colapse so it is still better than the 68 and older though.
Putting new rivit s in is a waste of drill bits and lots of time.
